Results 1 to 15 of 24
    Sep 2015
    Twin Cities, Minnesota
    Can a person go Left Handed?
    Just curious because I never ever hear of anyone running a single lefty motor on a boat. So if someone is selling their twin engine setup and they always have the left handed motor left last and selling it cheaper than a righty. Why cant you put a single lefty engine on your boat? with a lefty latham or what ever brand and prop and all that jive? Whats the big deal if your boat is symmetrical on the bottom. Why would it matter?
    Aug 2009
    savannah,ga
    Sounds like it would be just like driving an American muscle car.....bada** until you have to find a prop that works as good as a set of drag slicks for cheap. Lefty is fine and dandy but just costs more testing and tuning unless you have friends with leftys as well.
  3. Likes David - WI liked this post
    Lefty gearcases have about half the lifespan.
  5. Likes David - WI, W2F a V-King liked this post
    Lefty's also require more frequent oil changes. (the way the thrust is handled seems to burn the oil faster)
  7. Likes tux974, Dave Strong, W2F a V-King liked this post
    They also take a bit less lube more guts.
  9. Likes NICE PAIR, mistah_max liked this post
  10. #6
    I don't disagree with this but would like to ask the age old question "Why"? Any ideas? Thanks Gary
  11. #7
    Mar 2002
    N.E. Ohio
    Yes, they can. All the F1's do it. I know several guys here that have done it. It would be easier to turn left also. There was some stern drive company a while back that only turned left handed.
    Mirage Jaguar RiverRacer
    Polaris PRO785
    Bennington 255LCC
    Scream & Fly Flying Machine of the Month:
    September 2005
    http://www.screamandfly.com/showthre...ild&highlight=
  12. #8
    Aug 2012
    Tenkiller Lake, OK
    The left gear case holds quite a bit less gear lube due to the way the bearings are installed. A "lefty" can be spun either clockwise or counter clockwise because of the thrust bearings that resist the forces. They take up more room in the gear case. I feel that the reduced lube capacity is the reason that they tend to have a shorter life.
  13. Thanks olboatman, kct11 thanked for this post
    Likes David - WI, tux974, NICE PAIR liked this post
  14. #9
    Sep 2015
    So actually the entire engine rotates the other way as well?
    I thought it just in the lower unit. Or can it be either way?
  15. #10
    Mar 2010
    houston, tx
    Quote Originally Posted by MODVP22 View Post
    F1's use right hand gear cases. The motor actually turns to the left, in turn the in the prop the other direction
    a left hand gear case on a left hand motor would turn to the right.
  16. #11
    Sep 2007
    bay city mi.
    Quote Originally Posted by Davidlake View Post
    Are you saying you can run a lh lower hard in reverse and it will be OK?... Like with a rh prop
    South Africa
    A Lefty Box will live as long with either left hand or right hand props on it.
    Just not going to live as long as a Righty Box with right hand props on it.
    I am sure that the Verado style Lefty box is going to be almost as good as the Righty, very little different between the 2
  18. #13
    lost in Tennessee
    Quote Originally Posted by 90 5.0 View Post
    No sir, the F1 boats run LH rotation motors and LH rotation speedmasters. The new 200sst motors motors rotate RH and the gearcase takes the engine rotation and reverses it to LH rotation
  19. Thanks NICE PAIR thanked for this post
  20. #14
    Sep 2015
    So a lefty motor will rotate left (counter clockwise) because F1 racing is all left hand turns so if you want to call it the gyroscope effect, a motor rotating left can turn left easier because its going with the momentum of the motor rotation and not fighting against it? Something like that? Thats how I am interpreting it. Same goes for a prop that turns counter clockwise, its always turning into the turns instead of away from the turns... Do I have this correct?
  21. #15
    Running a left hand case on a fishing boat or similar will have no affect on how the boat performs. All the used Left hand props I've bought were about 1/3 the cost of a used right hand. I don't have any evidence the CR cases I deal with (brp) are weaker but due to their reverse thrust bearing you CANNOT run them in reverse with a rh prop on it. They willl not live long at all
  1. Set of Mercury 15 x 32 left and right handed cleavers
    By Spectre Powerboats in forum Propellers
    Last Post: 08-20-2016, 11:28 AM
  2. Mercury 3.0 left handed lower unit
    By THATGUYJOHN in forum Lower Units
    Last Post: 08-12-2014, 05:45 PM
  3. Left handed controls
    By 4cznskier in forum Technical Discussion
    Last Post: 05-01-2007, 12:00 AM
  4. running a left hand sportmaster right handed
    By 2.5-21 in forum Technical Discussion
    Last Post: 05-21-2001, 01:21 PM
