Results 1 to 6 of 6
12-27-2016, 11:29 PM #1
New Member
- Dec 2016
- Chicago
1972 Chrysler 130 under 100 or hours
This motor came off my fathers boat..raccoons had their way with the inside of it when it was covered in my dads barn..they trashed the inside so I decided to remove the engine and off the boat..I have everything except the steering cable to complete a full install.you can see from the pics that even the power head and carbs look like new..750.00 obo..
ps I have all the wireing,steering rack,gauges,shifter and shift cables..
pss,the cylinders were oiled every year and the engine was rotated...I started it last year and it ran great...since I fogged it and pulled the engine...
the engine only has like 80 original hours on it..Last edited by FIXX; 01-01-2017 at 05:43 PM.
FMP liked this post
12-27-2016, 11:39 PM #2
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
You need to get it turning , running. Check the compression, check the lower oil, give some details, does the trim work ?
12-27-2016, 11:45 PM #3
New Member
- Dec 2016
- Chicago
01-01-2017, 05:44 PM #4
New Member
- Dec 2016
- Chicago
Ttt..needs a new home..thanx guys..
01-01-2017, 07:04 PM #5
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Yup, good deal with all controls and rack. Looks good with correct large bore TC 1A carbs. For those that have a later style 77+ leg and powerflow lower this power head and lower and upper cowl as well as clamps and controls can be bolted up without issues. Do that with some port clean up and a shaved head to 165/170 and you've got a stout retro with great looks.
01-06-2017, 05:41 PM #6
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Add this http://www.powerboatlistings.com/view/17818
and some later clamps for the Sea Star and you're moving!
Done
1972 Sidewinder Help !!
By Scott Rogers in forum Technical DiscussionReplies: 35Last Post: 04-19-2013, 05:14 PM -
1972 glastron 14
By buzzm19 in forum Props, Setup, and RiggingReplies: 8Last Post: 03-11-2010, 06:42 PM -
1972 Mercury 115
By like24x4 in forum Technical DiscussionReplies: 1Last Post: 06-23-2009, 02:10 PM -
1972 FE production
By mdias7d in forum Outboard and Racing HistoryReplies: 5Last Post: 01-29-2004, 07:06 AM
