Results 16 to 30 of 31
11-08-2016, 05:33 PM #16
Yes it is a 25' Motion . I wanted one since I was a kid growing up in S. Miami . When the opportunity arose to buy one , I sold my 21' Superboat and bought it.
With 3.0L motor's set back 6" and everything other that the shifters and steering wheel crammed under the back seat , it was the biggest POS to drive . I hated it and wanted my Superboat back . With the help of some really good people , I got a better set of props , moved some weight around inside , made 15's out of the mid sections and then moved the motors forward 4" , and it became a whole different boat .
What helped , what hurt , I can't say because I did it all at once . But I would have to think that any cat that bounces around and lopes at a steady cruise speed needs some weight moved forward .
11-08-2016, 05:44 PM #17
5000 RPM
- Mar 2013
- Sunshine Coast, Queensland
- 208
- 64
How do I contact Sean?
11-08-2016, 06:45 PM #18
You can message Shaun
through Instagram or Facebook or call directly at (786) 229 - 58 zero one
https://www.facebook.com/shauntorrenteracing/
https://www.instagram.com/shauntorrenteracing/?hl=en
11-08-2016, 07:46 PM #19
Since we are guessing. My guess is a Bob's with a piece of 2" aluminum angle (turned in) used in lieu of the Bob's inner angle. Odd thing is those bolt heads didn't have to line up that close. Could have used different mounting holes on the OB.
tux974 liked this post
11-08-2016, 09:17 PM #20
6000 RPM
- Dec 2002
- Southside, Al.
- 1,262
- 54
- 45
- 83
- 412
OK, Thanks. Always have interest in setup and rigging information.
11-08-2016, 09:28 PM #21
Looks like the TH Marine I have on my flats rig. Inverted.
11-08-2016, 11:11 PM #22
11-09-2016, 01:30 AM #23
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,652
- 301
- 279
- 1791
- 1275
I have a plate like this on my Varmint. Unsure of setback but probably 2" or less. The cylinders are Ingersoll Rand "pneumatic" actuators. Trim pump in the boat runs it. It is unmarked, and possibly fabricated as the original owner owns a small foundry and made a Bob's stlye cav plate and transom saver in-house. I found the cylinders online and seems like they were almost $400 a pop!
Josh Peterson
11-09-2016, 05:25 AM #24
5000 RPM
- Mar 2013
- 208
- 64
Gidday guys
I am probably one of the few people on the planet who aren't on Facebook or Instagram, so got a friend to go onto Shauns Facebook site and get an email address. Unfortunately, the email I then sent bounced back as undeliverable. Would someone be good enough to drop him a line on FB or Instagram and check his email address for me. I used [email protected]
Thanks guys
11-09-2016, 06:28 AM #25
That was my exact thought!
The Bob's outside slotted L's, home made new smaller inside inner L's, redrilled or new drilling, use carriage bolts in the slot instead of hex heads and anodized not hard to fabricate.
Funny how the adjustments are mounted upside down, never seen that.
If the adjustment blocks are hexagon not square it's a Bob's copy that sells on Ebay.
I personally modified mine, made new blocks and adjustment hardware for the center 2 to adjust and function as one.
Easy enough to duplicate that setup with very little effort if someone is in need and could not find one.
All above posting is for the sake of discussion!
11-09-2016, 06:39 AM #26
The Historic Photo Master
- Jan 2004
- Florida
- 38,660
- 78
- 1765
- 384
- 20405
- 4 Post(s)
11-09-2016, 01:25 PM #27
Guys!!!
Its not a Bobs. Yes I mounted it upside down because I needed to drop my motor a half inch and coudnt without the jackplate.
It is a stock jackplate that was made in the 90's by THT or CMC I believe.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
rjdubiel liked this post
11-09-2016, 01:32 PM #2813' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
Slimm liked this post
11-09-2016, 02:12 PM #29
11-09-2016, 02:33 PM #30
7 to 3pm 5 days a week
Custom Fiberglass and Paint
In Business since 1984
for sale
Anyone on S&F live near Ruck Machine AKA Mag Machine Service or know Ron Magdanz?
By Mike Nass in forum General Boating DiscussionReplies: 6Last Post: 08-14-2018, 04:00 AM -
Any S&F's out there that live near Ruck Machine / AKA Mag machine or know Ron Magdanz
By Mike Nass in forum General Boating DiscussionReplies: 70Last Post: 10-24-2016, 05:43 AM -
Best workstand to build powerheads? Build? Buy?
By Zoomba in forum Technical DiscussionReplies: 6Last Post: 03-10-2014, 07:45 PM -
Mercury Tech: Help with build please
By CHEVYMAN434 in forum Technical DiscussionReplies: 3Last Post: 06-23-2012, 09:41 AM -
Build better and Safer Build Union
By SnakeBit in forum The Scream And Fly LoungeReplies: 38Last Post: 09-06-2008, 05:00 PM
