Results 16 to 30 of 32
    MIAMI FLORIDA
    I am making this for my v6 probably could go down a gage for a v4, used gr23 titanium for the tilt tube.Dave
  2. Likes loop liked this post
  3. #17
    12 Post(s)
    Quote Originally Posted by H2OPERF View Post
    Like was said above no real easy/cheap/light way out. A cut down omc mid isn't that heavy,make a sheet metal/angle mount bracket/jack plate with a trim cyl and a pump in the boat. For a v4 you could probably go with 3/8 instead of 1/2 on most of the pieces or do some custom milling lighten it up a bit, that will get rid of the heavy oem mount brackets and a big heavy jack plate made for a v6. Dave
    Agreed.
    I've done both a couple times and a cut down OEM mid is much lighter than a Taylor 16".
    And I think more attractive.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  4. #18
    Apr 2008
    Omaha, NE
    Skeleton mid looks awesome.
    Loop,
    Can you give the weights of stock vs your skeleton and more pictures when your finished with it?
    Can you give information on the fiber cowling?
    Thanks
  5. #19
    Alabama
  6. #20
    Quote Originally Posted by Freddie Webb View Post
    What a work of art....now ya got me droolin!!! Gary
  7. Thanks Freddie Webb thanked for this post
    Likes Freddie Webb liked this post
  8. #21
    Sep 2006
    Key Largo, Fl
    thats it
  9. #22
    Aug 2009
    mpls,mn
    Well im not saying freddy set up aint cool and all BUT to me it looks like the whole motor[powerhead pan hood lower unit] is only supported by that one piece of vertical tubing? might work for speed runs in calm water but turning sharp and or in rough waters boy if that weak spot failed and the whole motor fell off someones going to get real hurt or worse. jmho
  10. #23
    Aug 2009
    mpls,mn
    Another note is that the front on the powerhead skeleton that comes to a point at 4 spots that's welded to the vertical tube is what im talking about be very prone to cracking as the leverage of the rest of the motor would be very hard on those 4 points , anyone agree?
  11. #24
    Quote Originally Posted by racervboat View Post
    Ken I see the point you are making and isn't that tube the swivel point for steering? Very nice workmanship and owning one of your shortened v4 mids I can say your work is flawless also! Gary
  12. #25
    SE MN
    I believe Freddie's mid is for a drag hydro. I'm sure there will be more critical bracing.
    Rhode Island
    Quote Originally Posted by loop View Post
    im building this for mine
    not proud of it but it'll do what i want
    short and light enough. About $50 in mostly scrap metal
    that.is.awesome
  14. #27
    Aug 2009
    mpls,mn
    im sure its a mock up but its a untested rig??? Freddie will have to chime in.It still needs a top v-4 adapter plate to accept the adapter plate and water tube and tuner,and a adapter plate to mount the lower unit to it and it looks like it does not swivel at the vertical tube ???. By the way thanks gary. ken
  15. #28
    Aug 2009
    mpls,mn
    ccm needs to chime in on what he wants to do with a lightweight v-4 mid, ???? race .lake racer,drag hydro,all around use? for you our a customer???
  16. #29
    This is one I did for JPEROG about two years ago .
    Chris supplied the circular pattern reeds for the power head .
    It is a 3 cyl , 60 or 90 , dependin on which way you put the decal on ...
    It was pretty labor intensive . I had to do a set back because @ 15" the lower ran into the trim cyl .
    With the swivel shortened to 15" the side rubbing blocks didnt line up , so it needed to do ears and tabs .
    The mounts were shot , so we made new ones .
    The nose cone was too big for the little housing , so it took a little fitting to make it work .
    In my book , the can should be welded inside and out , this one was no exception .
    I think some time last year he bought a 115 HP Opti powerhead and slipped it on this mid .. his little Whaler handles good and hauls azz ...
    http://s217.photobucket.com/user/Tub...Daytona?sort=3
  17. #30
    Aug 2009
    Florence SC
    Go over to FB & look For Dusty Foskey posts.
    he is a welder & has fabricated one nice mid.
    3 cylinder PH w/ kr/v4 lower unit SLICK !
  1. OMC Tech: Crossflow V6 Hi Speed Electrical/Ignition Problems - Out of Ideas...Got Any???
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 10-04-2011, 01:10 PM
  2. OMC Tech: 235 Crossflow still has intermittent fuel pressure problems at WOT - ideas/opinions??
    Last Post: 11-04-2010, 04:09 PM
  3. OMC Tech: 140 Crossflow Performance Ideas
    By mfm in forum Technical Discussion
    Last Post: 08-19-2008, 01:20 PM
  4. V4 Crossflow tried to burn down today...AGAIN - Any ideas?
    Last Post: 01-01-2007, 09:26 PM
