Page 99 of 102 FirstFirst ... 49 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 LastLast
Results 1,471 to 1,485 of 1526
  1. #1471
    Jun 2013
    east islip ny
    Quote Originally Posted by JamesGang View Post
    Did you know your boat has a twin. And it will be at the Ct. river run this weekend. It now has a Merc 300XS on it.
    Attachment 357689Attachment 357690Attachment 357691
    Nice boats! How does that boat run with the 300xs?
  2. #1472
    Suffern, NY
    So far 85 but it probably has a little more in with some more prop testing and maybe a gear ratio change. He currently has 1.62 gears in a sporty and a 26" Pro Max.
  3. #1473
    South Carolina
    "Right at 70 with my 250 Merc on a 4" hydraulic jack plate. All original 1990 I bought in Michigan in 2003."
    Sorry, correction to my previous post, bought the Velocity in 2003...
    You cannot bring about prosperity by discouraging thrift. You cannot strengthen the weak by weakening the strong. You cannot help the wage earner by pulling down the wage payer. You cannot further the brotherhood of man by encouraging class hatred. You cannot help the poor by destroying the rich. You cannot keep out of trouble by spending more than you earn.
  4. #1474
    Sep 2008
    mass
    Only 85 out of it with the 300xs? Is it a stepp hull or regal?
  5. #1475
    Suffern, NY
    Stepp Hull. The 300XS just doesn't have what the X has. He's perfectly happy with what its doing. Pretty much what he expected. If we did a gear ratio change and play with props it would probably only get him to 87. Then even with the Dave Bush kit maybe 89. Not worth all that in his book. He likes it the way it is, good on gas and dependable.
  6. Likes Greg G liked this post
  7. #1476
    Sep 2008
    mass
    Dang I have a dbr 300xs I have on my 24 superboat that I was going to put on my 85 22 velocity when I was done rebuilding the boat and was hoping for low 90's
  8. #1477
    ft,myers,fl.
    always wondered if that was this boat .. but i guess it is a twin .. how cool !!.. got my transom done and found out the hour meter read 35 hours only ?? I actually think it could be all that was on it.....here is the transom 3.5 "thick ..4" taller.... my tank from sunshine should be done soon..
  9. #1478
    ft,myers,fl.
    some more progress on the boat .. foam stringers in .. floor pieces done with non skid...sunshine marine 50 gal. tank.....switch panels .. and a 250xb and some dana tabs for it.. still a long way to go
    Attached Thumbnails Attached Thumbnails 017.jpg   021.jpg   018.jpg   002.jpg   009.jpg
  10. #1479
    Suffern, NY
    Hate to rain on your parade but for knees to be effective you want the tied in to the stringer system not just stacked on top where it would be easy to sheer away. When doing stringers it would have been good to make them part of it. When adding to good stringers I would bond along side and go forward to the 2nd bulkhead then glass in and do a new shorter bulkhead to the knee. Once the floor is glassed on top everything is locked and the knee can't sheer from the stringer system. Its not too late for yo to something more substantial along side your stringers.
Name:	Stus Resto 13.jpg
    Here's a picture of knee bonded in before glass.
    This is part of the stringer.
  11. #1480
    Suffern, NY
    Here's the knees glassed in and then the floor glassed in. Couldn't find a picture with the back bulkheads in before the floor went down. Your job looks like it's coming out so good why not knock out those back two bulkheads, put in a real set of knees and then put the bulkheads back in.
Name:	Stus Resto 10.jpg
ID:	365577Click image for larger version.
Name:	Stus Resto 19 copy.jpg
  12. #1481
    Suffern, NY
    And then for the final finishing touches for ultimate strength. A bridge with radios rods tied from the bridge to 4" angle aluminum at top of transom. This last boat is my sons boat, the two above are mine and a friends.
  13. #1482
    ft,myers,fl.
    your right about the knees being set on top .. they need to be 1 piece from the side of the stringer up...I am also eliminating the o/b well and make the back like a skater...james gang did you glass over your tank in the rear??
  14. #1483
    Jul 2004
    Connecticut
    As is always the case, JamesGang offers spot on advice. 110% worth doing exactly what he says at this stage of your project. You'll never have to deal with anything in the future.
  15. #1484
    Jul 2004
    Connecticut
    Here is how I designed a similar approach just for some more ideas with a pic ..........
  16. #1485
    ft,myers,fl.
    the different designs on the knees are a must..... all of this is foam board except the transom which is 3.5' thick and should be strong with the top glassed in.... tomorrow I m going to do the knee braces better and add a layer of glass to the bottom between the horizonal stringer braces....... greg g that is some heavy duty bracing !!!
