Results 61 to 75 of 86
09-03-2016, 11:58 PM #61
Hey Armand, Any updates??? Hopefully you've been busy putting this all together !!!
09-04-2016, 05:10 AM #62
Hey Captain !
Yes very busy but also whit other things beside the boat as we need to keep funds coming !
We have finished up the second set engine mounts and put them in and drop down my engine i allready have and the test fitting engine to see if it all work out like we thought it would , also have ad some weight to the test engine so weight is same as engine that is complete and put on the drives transoms ,props ,tie bar and drive lines in the boat .
after that we lifted her on one sling to see where the cg point ( got the info from Dough ) is on this moment so we can shift weight whit all other parts that have to be mounted like trim pumps , batteries sea strainers ect .
Now busy selling my old headers as they are to high and ordering new ones from imco and sea strainers and other rigging parts so we can go on whit that , also looking into the fuel set up where to place the low pressure pumps , catch tanks and high pressure pumps and filters
well thats about it sir !
MeCapnDave thanked for this post
09-04-2016, 03:46 PM #63Wriggleys gum makes me think of boating, "Double your engines, Double your fun"
Scream And Fly liked this post
10-16-2016, 05:41 AM #64
A Little update and Big change of plans
A bit later then planned but still worth it I think , I found a set of my always wanted Arneson Asd 7 M drives !
After a week of thinking if I would go that route because we have to fill the notch change the engine mounts and fill the holes that I made for the bravo s again we will throw away a lot of work !
But as it was first my idea to build my dream boat whit those drives and ls engines to get a bulletproof lightweight efficiency boat I pulled the trigger !
So we are back to start again !
10-19-2016, 09:09 AM #65
Very nice hardware you got there!
03-05-2017, 07:54 AM #66
Update
A Little update as we now had to start over basicly , we have put the Boat upside down so we can work on both sponsons and Also do it much easier this way .
we made a Mold of the last 1.5 ft of the running surface so we have exactly the shape to fill the notch and Also make the running surface longer .
now the Molds are done we make inserties to put in that Will give us water ramps that provide the cool water to the transom mount pick Ups .
i hope we Will be able to start making a product next weekend and have Those ready to put in the notch end of this month because when this is done we can shape it And turn it back again to start On the Inside to build up The coring and Inside laminate and stringers so we are Back where we start of !
03-13-2017, 11:00 PM #67
I was in Maastricht a couple weeks ago but didnt have enough time to come see you. I was gonna catch a train to Amsterdam. That is a lot of work to change directions but you'll love the Arnesons !! Keep the updates coming !!!
bor liked this post
03-14-2017, 12:18 AM #68
Dave , then You was pretty close ! Should have been fun to See You here but im sure we can make that happen another time and hopefully the Boat is finished by then so we can take it out or at least You can see here finished as now it look worse then The last time You saw it !
If You ever Fly to AMS and have a Little time give me call as I m only 10 min from there i can always pick You up even if it would be for a Hr or two .
MeCapnDave liked this post
09-23-2018, 01:30 PM #69
Well it’s been a long time and a lot of work but the notches are filled whit waterramps build in inside all coring and stringers build back in .
boat is now I paintshop to completely being redone inside and out after that we can put back all rigging and windshield and start where we left a while ago
09-23-2018, 06:58 PM #70
09-24-2018, 10:14 AM #71
Thx nice pair for getting those pics right side up !
NICE PAIR liked this post
09-24-2018, 06:36 PM #72
Is this the same boat that was at Miami Boat Show 2yrs ago.
Double Rigged
308 Skater w/400r’s
Over-Kill
09-24-2018, 06:47 PM #73
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,991
- 679
- 1081
- 1917
- 7941
- 4 Post(s)
I think it was three years ago-yes.
09-24-2018, 11:07 PM #74
09-25-2018, 08:06 PM #75
Man how time flies. Wish you the best!
Double Rigged
308 Skater w/400r’s
Over-Kill
bor liked this post
I started painting and rigging Joe Perog's STV River Racer today
By WILDMAN in forum General Boating DiscussionReplies: 135Last Post: 08-13-2016, 04:47 AM -
Just started painting and rigging a new 2015 21ft liberator cat
By WILDMAN in forum General Boating DiscussionReplies: 44Last Post: 10-29-2014, 05:51 PM -
Finally started rigging.....
By baja200merk in forum General Boating DiscussionReplies: 474Last Post: 05-28-2013, 11:04 PM
