Page 71 of 84 FirstFirst ... 21 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 LastLast
Results 1,051 to 1,065 of 1248
Thread: little boats
  1. #1051
    Like the "Tool Man" would say..MORE POWER! Damn I got a 135 TOP on a 15 footer Flatty. I'd stuff a 75 on the back that boat..and a damn nice "tin" too!
  2. #1052
    Aug 2014
    Georgia
    Make sure you have a cupped prop on her and jack the motor so the cavatation plate is at least an inch above the bottom. The water p-up is on the exhaust snout behind the prop so there will be no cooling problems. Be sure the flywheel has the elect.starter ring gear removed. You can cut up to 60 thou. off the head(start at 45 thou.) but you will need to mix fuel up to 98 oct. if you get to 160 lbs of compression. Set up is the most important (motor as high as possible) and if you get her to spin over 6k rpm you need to use GOOD oil at least at 32:1(25:1 over 6.5k) Make sure throttle linkage is tight as carb and timing will not be at full setting if they are worn.I have modded a couple and hope this helps. Gary
    Thanks for the info Gary. Can you suggest how much could be milled off of the head and still run well with 93 oct.? Where do folks get 98 oct?
    Any sources for cupped props for this motor? I'm assuming you are talking a stainless or brass prop.
    I've got a new in the box Hi-Jacker jack plate and am considering using it but is seems a bit heavy considering the size of the boat.
    I'm thinking I should start a thread on my ship instead of hijacking this small boat thread.
    Thanks for all feedback.
  3. #1053
    Aug 2014
    Georgia
    Quote Originally Posted by tunnels View Post
    find the smallest lightest kid and teach him or her to drive !!that will do for starters!!
    The truth hurts!
  4. #1054
    Quote Originally Posted by VinTin View Post
    You would be fine @ 40k off head and 5k off block to get a good seal....be sure to use thin(original style) head gasket with 93 oct fuel.
    Send to a prop shop and have them cup one for you.
    Your prop and height of motor will give you the most speed improvement. Gary
  5. Thanks VinTin thanked for this post
    Likes XstreamVking, VinTin liked this post
  6. #1055
    Sep 2015
    Twin Cities, Minnesota
    Heres my 1970 14' GW Invader with a 115hp Merc and a 17 gallon tank. This is the same boat Team GW Invader put a 100 horse on and went 78mph.
  7. Likes VinTin liked this post
  8. #1056
    Jun 2008
    Sardis Lake Oklahoma
    LOL, That boat would run 80's with the 75 if it were set up to run!!!
    WillySteve Hendricks
    20XDC Bullet/Modified Merc 260
    295TF Charger/ProMax 225x-Sold!
    '83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
    '85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
    Freedom 240 DLX Fisher Toon/Merc 115
    10' Cougar Cub/Merc 25HP On The Bottle!
    18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
  9. #1057
    Lake Havasu City, AZ
    TLM Tsunami
    Our latest Tsunami build. 50HP Tohatsu 4 stroke.
  10. #1058
    Aug 2014
    washington
    15' tunnel with SST motor.
    http://www.dillon-racing.com/custome...ilde/index.htm
  11. Thanks boatermike thanked for this post
  12. #1059
    Aug 2014
    washington
  13. Likes Outlaw45, Capt.Insane-o liked this post
  14. #1060
    Aug 2014
    washington
  15. #1061
    Aug 2004
    Venice, Florida
    Dont think I added this to the thread yet.
Name:	101 avatar.png
    21' Paramount
    Mercury 300 Promax
  16. Likes tunnels, bahamaboats liked this post
  17. #1062
    Dec 2016
    NH
    New to this forum. I got this boat out of barn clean out (pic). Its a Columbian Fury 8' for the 1960's. I am in the process of restoring it in my basement(pic).
    I cannot find pictures, posts or anything on this. If any one knows about these boats that would be helpful. As of right now I will assume it will take a HEMI.
ID:	362550Click image for larger version.
  18. Likes Mr. Demeanor, Capt.Insane-o liked this post
  19. #1063
    Quote Originally Posted by sleezstak View Post
    Welcome to S&F...I'm sure you will like the members and info here! I would also post your interesting craft on the fiberclassics website as there is a wealth of knowlage on older fiberglass boats on that site. Have fun! Gary
  20. #1064
    Aug 2016
    Southwest Mi
    1985 12' Alley Cat Sanger
    1985 12' Alley Cat Sanger we picked up this past fall.
    70 hp. Yamaha.... X- Dimension needs to be dialed in.
  21. #1065
    Rhode Island
    My 13.5' tunnel hull build still coming along... Going to go with a 115 Pro XS for her this spring. Trailer is way overkill, I know, haha.
ID:	362582Click image for larger version.
ID:	362583Click image for larger version.
ID:	362584Click image for larger version.
    And here's a little home-made boat ! Older brother during the Flood this summer in Norfolk, Virginia.
ID:	362586Click image for larger version.
  22. Likes Mr. Demeanor liked this post
