Results 1 to 4 of 4
Thread: Ignition system
08-07-2016, 11:07 AM #1
5000 RPM
- Oct 2004
- lehighton, pa
- 117
- 18
- 37
Ignition system
Can you use the same wire harness and key switch from a 2.4 to a 2.5 both are carb motors. Boat starts but runs like crap. Seems like it's missing then does like a hard shut off. I looked on the cat I never had a fuel regulator on that boat and it ran. I did have 1 coil wire bad, fixed that. To be honest I thought it ran better with that coil wire bad..Any ideas?
08-07-2016, 11:55 AM #2
Harness should work fine.
sicknick12 thanked for this post
08-07-2016, 03:36 PM #3
Back in the day I had an old '78 175 Black Max that wore me out for a week.....finally found that the big ground cable had work-hardened and broke almost in to where it goes through the cowling!
sicknick12 liked this post
08-08-2016, 02:59 PM #4
5000 RPM
- Oct 2004
- lehighton, pa
- 117
- 18
- 37
Thanks guys, Yes I had a few bad wires I narrowed down going from the packs to the coil
Complete CDM ignition system
By 2.5-21 in forum Misc. Parts and AccessoriesReplies: 2Last Post: 09-30-2015, 02:12 PM -
MSD Ignition system
By Doran59 in forum Technical DiscussionReplies: 1Last Post: 08-25-2008, 06:39 PM -
OMC Ignition System
By imq707s in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 07-02-2004, 03:43 PM
