Results 1 to 15 of 20
    Jul 2004
    houston,tx
    2.5 timing settings off from other motors
    have a WTF is going on ?
    have triple 2.5 260+ motors on my boat
    from time I built the motors my center motor timing arm
    has to go almost to where the arm stops hitting the top cap bolt
    to get my 25 deg full timing,,,,max arm travel maybe hit 26
    the other 2 timing arms in basic same location or common area
    im used to seeing for last 20+ yrs
    motor runs fine.......
    couple weeks ago I lost a switchbox on this motor
    so bought new rapair trigger and 2 switchboxes to put all new
    when went to time arm hit its end at 22deg,,,,huhh
    so rechecked tdc with dial indicator and 150 for 25 deg timing on flywheel
    so swapped flywheel from other motor,,,same 22deg,,,,
    put on another stator,,,knowing stator just makes voltage,,,but still tried,,,same 22
    put on another merc trigger,,,not the same original,,,went back to 25 with arm running out of travel
    ,,,,,,again is running fine and plugs are reading like other 2 motors,,power seems the same
    so ? is
    could this crank be twisted some? if so then maybe 2-6 timing is off a tad if #1 times out
    or when merc made crank they had the splines off just a bit,,,,,
    makes u go WTF
    john
    If it indicates out as you say; doesn't it almost have to be the little link at the top of the timing arm that connects to the trigger?
    Jul 2004
    houston,tx
    thought of that when 1st put it together,,,,,over a yr ago and approx. 125 hrs and still runnin good
    link is screwed all the way in making it as short as possible an I even flipped it as the 90deg elbow is longer on 1 end
    as stated the other 2 motors time out where I have seen them for yrs,,,,,,about the same length on the stopper screw on the arm
    ive been timing v6 mercs since 1981,,,,,,so kinda got degreeing down,,,
    this crank can screw stopper till does not touch block and trigger arm hits top cap
    and with the new trigger wouldn't make 25
    used merc trigger does but barely
    plugs and piston tops have same look as other motors
    as why gotta be crank off
    just never seen it before and seeing if any1 else seen it
    Doesn't the link have to be longer if you want more advance?
    Jul 2004
    houston,tx
    trigger arm is behind throttle arm
    so shortening the link pulls trigger arm closer to throttle arm
    again trigger arm is running out of travel to get to mark
    as is crank spline are in wrong location,,,thus starting timing retarded causing having to move trigger further
    to get to idle and full timing locations
    Jun 2008
    Sardis Lake Oklahoma
    It could be twisted a bit John but if the merc trigger gets you to 25 then I'd run with it if there's no additional vibration.
    Running N2o on my old motas, I've broke driveshaft's at the upper splines and twisted splines on several propshafts but never seen a crank twist but it's dang sure possible!
    JMO
    Jul 2004
    houston,tx
    yes it times out just the trigger goes 1/4" window further than any other ive ever adjusted
    and been runnin them hard over a yr
    cruise 5-6k all day long
    and take to 7500+ when water conditions are good
    when the 1 switchbox failed got me thinking about it again,,,,,lol
    I run over 100gallons through motors every time out and past over 100 hr in last yr
    flywheel hub/trigger gives the signal so gotta be a spline off from factory
    as spline is all straight and flywheels slide on smoothly with no burring on splines
    or its a bit twisted,,,,,,,
    just asking if any1 else seen it
    as in 30+ yrs and a few hundred builds never seem it,,,,,,
    Nov 2005
    Malta, Europe
    I would try to swap the flywheel,unless you already did
    18 ft Speedcraft - Offshore
    Bottle Fed Merc tuber 2.4
    Jun 2008
    It's alot'a work but you could switch stator, trigger and flywheel from another engine and see if the problem moves. If it don't it has to be either the crank or the upper bearing carrier!
    Jul 2004
    houston,tx
    already stated on 1st post
    have used 2 different stators,,,3 different triggers,,and did swap flywheels
    as stated rechecked with indicator tdc and 25 to the timing marks on wheel to pointer
    the flywheel change did not change timing on other motor
    the new rapair was off from a merc,,,
    and 2 mercs hit timing mark
    just only factor staying same is the crank spline,,,,,
    so spline in my mind has to have been cut off some,,
    or crank has a twist
    don't see how a bearing carrier can change timing
    crank is not shaking,,,,flywheel is steady when running
    but all 3 motors have the same upper cap
    and timing arms
    have to use all of triggers travel to get 25
    and timing arm stop to block is way shorter for the more travel to get timing to hit mark
    motor runs fine,,,,been that way for many hrs of run time
    forgot about it till I lost a switchbox
    and wanted all new electronics
    as its an offshore boat and go 100+ miles in a day all the time
  11. Likes WillySteve liked this post
  12. #11
    Nov 2005
    Malta, Europe
    With all the above mentioned the crank splines must be off. I doubt the crank is twisted though
  13. #12
    Jun 2008
    The only reason I mentioned the Bearing Carrier is because the window in the casting could limit the travel of the trigger were it off a little!
    JMO
  14. #13
    Jul 2004
    houston,tx
    my thoughts also,,,,,
    as never seen before timing arm to go approx. .0320 more than another to get 25
    measuring the length of the stop screw on the throttle arm
    and really is more as I adjusted the trigger swivel as short as possible to advance timing more to arm location
    just never seen this and wondering if any1 else ever had 1
    I guess it was a Monday crank and their alignment indicator was off on the spline cut
    is only thing making sence
    u guarantee another crank is going in when I refresh motors
    just for peace of mind reasons,,,,lol
  15. Likes WillySteve liked this post
  16. #14
    Jul 2004
    houston,tx
    Quote Originally Posted by WillySteve View Post
    JMO
    yea I figured so as why said they were all same top bearing caps
    all 3 are 260 unpainted caps
  17. Likes WillySteve liked this post
  18. #15
    But one spline off would be over an inch out at the rim of the flywheel; I just can't believe that would get by even a casual inspection. I guess anything is possible but it seems like there has to be something else going on.
    When you indicated it out, your "0" would have been off by about 1-1/8" I think.
    Edit: never mind... it could be off by any amount; not necessarily 1 spline.
  19. Likes WillySteve liked this post
  1. Timing settings 20 hp Merc
    By SS170 in forum Technical Discussion
    Last Post: 03-09-2016, 05:07 PM
  2. Mercury Tech: DDT settings
    By skydog in forum Technical Discussion
    Last Post: 08-27-2009, 01:05 PM
  3. Merc 115 Timing adjustments & settings
    By DEYS in forum Technical Discussion
    Last Post: 07-05-2008, 12:00 PM
  4. TPI settings
    By wjtrahan in forum Technical Discussion
    Last Post: 07-27-2006, 05:08 AM
