Results 1 to 10 of 10
Thread: electric fuel pump opinions
07-28-2016, 01:56 PM #1
I am going to install an electric fuel pump if I cannot clean up my bog with jetting (some have said it helps). Looking for opinions on what some feel is the best option for carb V6 OMC (or Merc carb V6 since I have one of those going on another boat if I ever finish it). I have read just about every single post that I can find but when it comes to carter pumps the posts don't list many part numbers/model of pumps. I am not looking to break the bank so the options I think would work are below, and yes fuel filters will be part of it since anything getting into the pump can cause issues.
Holley Red
Holley Blue with reg that comes with it.
Carter P4070
Carter P4389
Carter P4594
Carter P46001973 Viper - sold
1978 Viking - sold
1995 XB02
07-28-2016, 03:10 PM #2
Myself, I would run the Holley blue which is about 14psi and regulate it down to whatever you need for your motor. I think it gives you more control of your fuel pressure that a 7psi internally regulated pump.
07-28-2016, 04:09 PM #3
Thanks for the reply. Anyone use a Carter P4389 that is 4-6 psi - 72 gph? So many posts about Holley VS Carter on reliability and noise. Either one I would guess will be sufficient for my application.
1973 Viper - sold
1978 Viking - sold
1995 XB02
07-28-2016, 06:15 PM #4
Which one of the Carters can draw from a top feed tank? Lifting about 9 inches total from the bottom of the tank then push to the Separator and then motor.
I carry a gun because a cop won't fit in my pocket.
1987 Glasstream 15V
1986 Mariner "Tower of Power" 115
07-28-2016, 06:31 PM #5
I got a red you can buy if you decide on that....I have always ran them with zero issues on OMCs but you should have the fuel line out of the tank connected at back and on the bottom, if at all possible. They are noisy buy your boat isn't what I would call "quiet" lol! You NEED compression too.....even if its another 15-20psi! Let me know if I can help....you have my number bud
SchramerI have a boat or two.... that I never get to drive
07-29-2016, 08:18 AM #6
Junior Member
- Jun 2005
- Chattanooga, TN
- 22
+1 on the blue pump with the reg.
I have run one for years - zero problems.
Fine tuning the pressure with the reg. might be the solution for you.
rjdubiel thanked for this post
07-29-2016, 08:43 AM #71973 Viper - sold
1978 Viking - sold
1995 XB02
07-29-2016, 09:02 AM #8
Carter pumps tend to run with less noise.
07-29-2016, 09:46 AM #9
I run 2 Mallory 4110 M 7 psi they are quiet and supply plenty fuel for 245's have 6 psi at the carbs after the fuel /water filter easy on amps even with 9 amp system
last set lasted 13 years before i put in new brushes,and armature in one
and found a low hour one from member on this board . carters were my 2nd choice if i could not get my mallorys going
rjdubiel liked this post
07-30-2016, 09:04 AM #10
At least on mine, the noise of a fuel pump won't be very noticeable with that TOP out back.
1987 Glasstream 15V
OMC Tech: electric fuel pump on V4
By rjdubiel in forum Technical DiscussionReplies: 3Last Post: 10-06-2015, 01:43 PM -
Installing Electric fuel pump on Looper, do I need to remove the VRO Pump?
By imq707s in forum Technical DiscussionReplies: 6Last Post: 05-12-2005, 02:21 PM -
electric fuel pump, through factory pump, or by pass?
By WATERWINGS in forum Technical DiscussionReplies: 6Last Post: 06-02-2003, 11:38 AM -
Electric Fuel pump-vs- stock pump
By B.Mac in forum Technical DiscussionReplies: 29Last Post: 10-11-2001, 03:49 PM
