Results 1 to 12 of 12
    jonesville, La
    Will 200 drive shaft fit sportmaster
    Trying to find a new 15" lower unit for my Ally, just wonder if my 200 15" shaft will swap out if I can't find a 15" sporty
    Jan 2008
    eatonton ga
    Yup it will
    19 bullet
    82 v king
    84 v king
    93 stv pro comp
    07 venom
    80 gt20
    93 v-21
    89 stv procomp
    97 xr 2001
    89 stv pro comp
    82 17 action marine
    99 action craft flats boat
    88 xr2002
    90 Stv pro comp
    10 mirage 1/4 master
    98 mirage 1/4master
    Mar 2010
    houston, tx
    The older 200 shafts were single bearing and won't work in a sm with duel bearing without doing some rigging. I don't know if the newer 200 cases went to duel bearing or not.
    Dec 2011
    Ludington michigan,on the shore
    There are a ton of one bearing sportys out there now.If your not wave jumping,there's no need for the extra bearing.You can ether use a 200 shaft,or knock the cage and rollers off the second bearing of the sporty shaft,leave the inner race,then set it up as usual.
    Jun 2004
    port st. lucie, fl
    you can use it with both bearings, we machine them here to accept the second bearing, 125$.
  6. Likes tux974 liked this post
    It sure will! I suggest to machine it and install the second. There was a reason the second bearing was introduced to the shaft.
  8. Likes Dave Strong liked this post
    jonesville, La
    Anyone got a sporty or coned 15" for sale
    Sep 2006
    Key Largo, Fl
    Quote Originally Posted by pappa pete View Post
    I can cut/shorten,re-spline and harden a 20 or whatever...in or out of the gearcase...,Chris
  11. Likes tux974, WillySteve liked this post
    Jul 2004
    Connecticut
    I have to check but I believe I have 15" in Sporty, CLE, and coned 200 up in the cobweb motel above my garage.
    Mar 2010
    houston, tx
    What gear ratios ?? any of them 2.0? Especially the 200??
  14. Likes caymanpowerboats liked this post
    Jul 2002
    FT WORTH, TEXAS
    second bearing serves one purpose only and thats to keep the drive shaft from moving up and down on rough water IE wave jumping i cant tell you how many of the small bearings ive took off sportys and tossed them, the 3.0 drive shaft has been the standard replacement for those guys who like the second bearing just have it resplined its not as hard as hipo shafts but set up right it will last long time me im running one bearing on everything
  16. #12
    Jul 2002
    FT WORTH, TEXAS
    i may have a set of 2:1 sporty gears laying around somewhere i know i have 8/10 heavy duty carriers cles and sporty ( no they aint the same)
  1. wtb 20 or 25 sportmaster drive shaft
    By darkstar6g in forum Parts Wanted
    Last Post: 07-08-2015, 05:03 PM
