Results 1 to 15 of 25
    May 2011
    Sweden
    Lost a blade on my 3 blade Mercury Lightning ET and ......
    Hi! Lost at blade on my prop yesterday and sadly the the blade took a piece from my Sport Master.
    I have another prop to run with, but the question is: Is my Sportmaster good to go? Or will it fall in to pieces if I just keep running it? Could it be dangerous to run at high speed? What shall I do?
    The gear case is almost brand new and is in super good shape aside from this.
    Some more info about my boat:
    Boat: Allison SS 2000
    Motor: Mercury 2.5 EFI 280
    Top speed: 108 mph
    Thanks in advance!
    Regards,
    Oscar
ID:	348609Click image for larger version.
ID:	348610Click image for larger version.
ID:	348611Click image for larger version.
ID:	348612Click image for larger version.
ID:	348613Click image for larger version.
    Jul 2005
    Locust Grove, OK
    Gearcase should be usable? Just keep an eye on this area, since it's probably going to crack being close to those 2 mounting holes.
    I'd weld it up asap.
    Thanks,
    Tim Bostic
    Hoss Marine Propellers
    www.hossprops.com
    918-479-5167 (shop)
    Pugh Hydro w/260 Merc - 12" mid
    1987 XB2002 Allison w/2.4 EFI Merc - 15" mid
    1985 XR2002 Allison w/2.4 EFI Merc - 12" mid (Restoration Project)
    "New" - 1987 XTB21 Allison (Refurbished at the Factory!!!!) w/'99-225 ProMax Merc
    Top Speed Blog - http://www.screamandfly.com/blog.php...OSS-quot-Style
    Jul 2015
    NC/TN/KY
    Those ET's are time bombs. I'm replacing mine and hanging it on the wall as art. Should have hung up my last Bravo1 that was worked on my cat but it is not being run.
  4. Likes XstreamVking liked this post
    I run an ET, I know their history, and I do not use it as an "every time" prop. It's more of a I need a little more speed to outrun this other boat kinda prop. Chopper is my every time prop. ET's seem to have a limited lifetime on them, maybe due to blade flex? Mine is labbed, which is even thinner than stock. IMO, they are a true "racing" prop.....
    Jul 2015
    NC/TN/KY
    I am trying to replace mine with a Mazco RE4. Should be here today on teh little brown truck.
    Dec 2011
    Ludington michigan,on the shore
    Check the propshaft for runout,That case needs to be fixed now.With a proper repair it will be fine.If you run it and it cracks through,the chances of a successful long term fix get slim.
    Dec 2012
    HUDSON, FLORIDA
    SO much for made in the USA try a scorpion if u can its a chopper-deluxe but thru=hub for great holeshot super lift less torque
  9. #8
    I don't use the word stupid often, but that may be the stupidest statement I have seen in a long time.....The USA makes some of the finest equipment in the world. You run your tiwanese scorpion bud....I will keep running my MERC props.....
  10. Likes specboatops liked this post
    Jul 2015
    NC/TN/KY
    Quote Originally Posted by outasite View Post
    Mine took out the bearings and prop shaft. Turned it into a prop shart.
    minocqua, wis
    one reason i dont run et's or even think about buying a pair
    cutting choppers into et's they break also . had great luck with cleavers ,mercury, mazco and mach
    Aug 2004
    Venice, Florida
    I would go in with a grinder and round that out removing any sharp edges or corners.
    21' Paramount
    Mercury 300 Promax
  14. Likes WillySteve liked this post
    Mar 2006
    auckland new zealand
    I have broken many props. Bud If I was you check the propshaft for run out. Check gear oil and keep an eye on it. Like others said clean up the edges on the box
  16. #13
    Dec 2011
    That area on sportys that are used in surfacing applications are prone to cracking with the web intact.Run it with most of the web ground out,IMO it will be short lived.
  17. #14
    Gothenburg, Sweden
    Stalproppen, if you need a Sportmaster in Sweden, just let me know. I have a good one (built by Steckbauer) on the shelf.
    Thin high performance propellers tend to throw blades. It is not just ETs.
    If you get someone to weld on your gear case, make sure it is someone who knows what they are doing.
  18. #15
    May 2002
    Harriman, TN
    Are the ET props really any worse than all the others we run high and fast?
  1. Drag 4 32p, Hoss 4 blade 28p, mercury et 3 blade 32p
    By Mercaholic86 in forum Propellers
    Last Post: 05-02-2016, 02:41 PM
  2. mercury et lightning vs. cut big blade chopper et
    By jeffsnowboarding in forum Props, Setup, and Rigging
    Last Post: 08-05-2014, 09:33 AM
  3. 26 Pitch 3 Blade Lightning ET
    By Allison982003XB in forum Props, Setup, and Rigging
    Last Post: 07-27-2009, 10:40 AM
  4. Lightning ET 4 blade
    By stokernick in forum Props, Setup, and Rigging
    Last Post: 10-11-2006, 07:07 AM
