Results 1 to 14 of 14
    May 2016
    TX
    Connecting Rod Difference
    I had to replace 2 rods for my Merc 175hp, 2.4l. The rods I received are bigger on the small end, and weigh about 22 grams more than the original rods. Is this going to cause any problems?
    Thanks
    Click to enlarge:
    Dec 2011
    Ludington michigan,on the shore
    Did you order by the casting number? Are they the same width at top and bottom? Your new one looks kinda like a 141 top guided.
  3. Thanks Fisher77 thanked for this post
    May 2016
    TX
    Numbers on the old rod are, 636-8118, Y. 26, new rod is 38, 636-8118, 38, E. That is all the letters and numbers on them. They are both the same width at the top and bottom.
    Dec 2011
    Well it sounds like that is the "updated version" of the rod you have,If you could shave some weight off and get them closer to the others it would help.If you could get them within 10/15 grams for a non hippo motor that would be fine,and I'm sure there are hippos out there running fine that are farther off than that.
  6. Thanks Fisher77 thanked for this post
    May 2016
    TX
    Thanks outasite. I dont have any way to shave them other than taking a grinder to them.Might could find a machine shop around here to do it. Problem is, all of the machine shops here are automotive based. Dont know if they would even touch them.
    ft pierce fl
    if you got a good price on the 2 rods. i would see if the seller has another 4 of the same. that would be my choice. they look more durable.
  9. Thanks Fisher77 thanked for this post
    May 2016
    TX
    While waiting for the 2 replacement rods to arrive, I was cleaning, checking, and installing pistons on my other ones and found what might be yet another problem, with another rod. When I put the rod cap on, it locks into position where it was split in half, but my fingernail catches on the split. My nail also catches on the inside where the bearing rides. I have tried to reposition the cap several times, but my nail continues to catch. I tried with the bolts untorqued, and with them torqued. I cleaned the mating surfaces, the threaded hole on the rod, and installed new bolts. No dice, still catches my nail. I figure it is not good, but this is my first time dealing with this type of rod design. I deal with automotive, and diesel engines. Whole different ball game. Is this going to hurt anything?
    SE MN
    I wouldn't run it.
  12. Thanks Fisher77 thanked for this post
  13. #9
    Dec 2011
    Don't run it,in a short time it will start to fret right at the parting line. Or worse!
  14. Thanks Fisher77 thanked for this post
  15. #10
    May 2016
    TX
    Thanks for the replies. I am beginning to wonder if I will ever get this thing back together. It's one thing after another.
  16. #11
    Dec 2003
    Breaux Bridge, LA
    I have a set of the rods you need.
    Let me know.
    XR2001 & XB2002
    Jul 2002
    FT WORTH, TEXAS
    check them all with them torqued together its in the mec manual take a sharp pencil and run it around the inside with the cap TORQUED down if it catches toss it let me know how many more you need
  18. #13
    May 2016
    TX
    Quote Originally Posted by TEXAS20225 View Post
    Will do, I appreciate it.
  19. #14
    Jul 2002
    FT WORTH, TEXAS
    i keep all rods stored torqued down they sometimes spread out just setting
  1. 2.4 connecting rod #s
    By STVRacing in forum Technical Discussion
    Last Post: 10-29-2003, 08:40 AM
