Results 1 to 15 of 15
    Oct 2015
    Kentucky lake
    Carbed motors in rough water??
    Ive got a 2.4 carbed bp motor that cuts out in rough water for a split sec on impact of 2' waves or bigger... just wanting to know if it was possibly the carb floats doing something to make it drop rpm then pick up again. .
    Jun 2009
    central minnesota
    some hp motors had a slosh plate in carbs,others will chime in shortly-th
    Ok im searching my memory but I remember someones boat in our shop that did this and it turned out to be the trim limit module. Just a thought. You may or may not have one.
  4. Likes Slimm liked this post
    Jul 2004
    houston,tx
    we raced carb motors for many yrs,,,,,
    3 things I found to keep em crisp in the rough
    if floats are set to high fuel will splash up through the brass vent tubes into the ventura
    and momentary flood the motor
    so have to set them a bit lower/below level
    baffles mounted in the float bowls help a lot to keep fuel from sloshing upward towards the vents
    and flip the primer solenoid upside down,,,,,with the primer mounted upwards and have wave impact sometimes primer can open and add fuel
    Oct 2015
    Kentucky lake
    ok thanks guys ill look into all of that.....
    Oct 2015
    Kentucky lake
    I do have a trim limit thing on engine harness.... can I do away with it some how to elitmate that possibity.
    Pekin, IL
    Yes you can.
    Rock
    Team Junk
  9. #8
    yes its like a mercury switch, liquid metal mercury, it would "splash" around and intermittently cut motor out
  10. #9
    Oct 2015
    Kentucky lake
    Ok i took the trim limit piece off and taped the wire up and out of the way... ill try it like that first. .
  11. #10
    new york babylon
    I had a battery switch die on me every now and then.
  12. #11
    Oct 2015
    Kentucky lake
    Trim limit switch was the problem thanks so much guys..
  13. Thanks 1BadAction thanked for this post
    Likes 1BadAction liked this post
  14. #12
    Dallas, TX
    Quote Originally Posted by Keaten View Post
    Thanks for answering back with the solution, I was debating on removing mine and this made my mind up.
  15. #13
    Oct 2015
    Kentucky lake
    Yea I've got my confidence back in boat again
  16. #14
    Pekin, IL
    I have seen that switch cause issues more than once. Glad ya got it going.
    Rock
    Team Junk
  17. #15
    Im batting 500
  1. Replies: 634
    Last Post: 08-19-2015, 01:57 PM
  2. Nissan 40 hp carbed water pressure ?
    By NNT in forum Technical Discussion
    Last Post: 06-19-2007, 03:02 PM
  3. Rough water
    By Pro300x24LD in forum General Boating Discussion
    Last Post: 09-12-2006, 09:59 PM
  4. SoCal Poll - Rough Water - Smooth Water
    By company man in forum General Boating Discussion
    Last Post: 05-26-2005, 12:21 AM
  5. Two Carbed Motors Off One Electric Fuel Pump??
    By Instigator in forum Technical Discussion
    Last Post: 03-15-2004, 04:39 PM
