Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
  1. #31
    Seat mounts look like they have a lot of flex in them. Hope they survive.
    How hard is it to keep your foot planted on the throttle when in rough water?
  2. #32
    Aug 2009
    Guernsey, C.I.
    The seat mounts are carbon/Kevlar composite that hook over the stringers, mine has stiffeners running width ways across the bottom, we tried the nav's without but will probably add them. I doubt they'll break, it's a complex of 450g carbon / 2 Kevlar / carbon / 2 kevlar / carbon. Extremely strong and lightweight.
    we haven't tested in proper rough water yet, I don't expect to drive with my foot planted, the steps should allow me to run much faster than a pad V though as it naturally runs wet. I can comfortably run planted in a couple of feet of chop, it gets much rougher than that here though, and our massive 30ft tidal range combined with the wind of the English channel and the overfalls created by varying depths of water makes for some unique conditions!
    Phantom 19G-R - E-TEC 115HO
    www.facebook.com/slayeroffshore
  3. #33
    Aug 2009
    Guernsey, C.I.
    Here's some pics of the seat base build
  4. Likes Kcraft liked this post
  5. #34
    Sounds like you will be very busy!
  6. #35
    Guess time will tell if it holds up to the pounding. Looks great.
  7. #36
    Jul 2004
    Connecticut
    Quote Originally Posted by mariawhitetrash View Post
    I can supply you with the solid top mounts, they're done by the same company that did my wing plates and tilt tube. The bronze bushings were done by my brother to suit, the factory tolerances are too sloppy for off the shelf bushes
    You and your team are doing some very top shelf work. Very innovative. We just bought a 2010 250HO which will be our first ETEC.
  8. #37
    Aug 2009
    Guernsey, C.I.
    Thanks very much, we do our best on a tight budget!
    What's the 250 going on? I highly recommend Sam Jenkins' solid mounts, be sure to pair them up with a good set of bronze bushes in the steerer and tilt tube for the best longevity and handling to match the power and torque of the big block
  1. Offshore race boat build - Bernico F2 Extreme
    By mariawhitetrash in forum General Boating Discussion
    Last Post: 10-05-2012, 06:30 PM
