Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 86
  1. #31
    Sep 2007
    the netherlands
    Quote Originally Posted by tmoore View Post
    Mine are 1 1/2" above the bottom and I think another 1/2 up would be better.
    I would liked to start at 3.5" above and then go down but that is not possible so we see how it will do at 2" above or maybe lower its all depending on testing as no body have done this set up so we will see , also like Fujimo say there are a lot things that are involded in it a simple prop change can make a world of differents
  2. #32
    Jul 2015
    NC/TN/KY
    I bet your checkbook and CC are getting worn out man.
  3. #33
    Did you say you are using standard Bravo One drives? If you are, how will you be getting cooling system water? (Or did I miss this in the thread somewhere?)
  4. #34
    Sep 2007
    the netherlands
    I thought I mentioned it , Bravo sportmasters lowers and if I have not enough water whit the -2" I make seperate water intakes in the hull
    Maybe you mean Tim he have normal bravo 1 drives on his 24 skater
  5. Likes AZMIDLYF, NICE PAIR liked this post
  6. #35
    Quote Originally Posted by bor View Post
    ...Bravo sportmasters lowers and if I have not enough water whit the -2" I make seperate water intakes in the hull...
    Excellent. You should have sufficient pressure/volume... ...And the ITS is the only way to fly.
  7. Likes NICE PAIR liked this post
  8. #36
    North Texas
    Yes, I have regular Bravo 1 drives that I've lengthened the skegs on. I really need to convert them to 1 1/4 propshafts, I've broken 2 of them.
    I'm also running through hull water pickups.
  9. #37
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    Cool
    excellent thread! love out of the box thinking
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  10. Thanks bor thanked for this post
  11. #38
    Jul 2015
    NC/TN/KY
    bor will have this thing running as well as it can. He is not just any boater, he is a skilled mechanic, machines whatever he needs, does pretty much anything he wants, and he has a hell of a good New Years party, I have the video.
    Looks like things are moving along there, looking good. I am sure you will get the most out of the Predator and I hope you like it. No chine walk there anymore. Do you ever drive your V you sold your Brother-in-law just for fun? What did he repower with?
    Things are going well here, hope to run my Intimidator tomorrow, going down to change the registration numbers from NY to TN and be all legal and stuff in a couple hours and then prime the fuel system and if I get done early enough try block off the transom mounted water pickup and hopefully use my IMCO lower cone adapter on the sportie or figure out a way to get her fired up on the hose and the fogging oil out of it and scan it while running on the hose just to make sure no faults.
  12. #39
    Sep 2007
    the netherlands
    Quote Originally Posted by Baja170 View Post
    You must be good in bets !! Yes it is but we have lot of work so we can keep the project going on step by step !
    Thx for the kind words Will !
    I never have sold my 21 ,still have it and there s a 5.0 mpi in it but still need a drive as the one I had is been sold and also have to hook everything on the engine but its hard to work on that while the cat is next to it !
    But its fun to steer it out of the chinewalk and keep it balanced
    We are now fabricate a couple of custom alluminium offshore mounts for the ls and make some inserts that I have to build in the cockpit floor to mount the seats ,for the show we had them screwed down simple as I wanted to figure out the right spot for the seats back home .The outside can be bolt thru the floor in to the sponson but the inside is above the tunnel so have to make a insert in the floor that hold them secure in the rough .
    Great to here everything is ok ! Shoot me a couple pics thru fb or text of the intimidator and tell me how it runs !
  13. #40
    Jan 2008
    Daytona Beach Florida
    Hello Armand, I had dinner with Doug Wright Saturday night and he's excited about seeing your boat finished. The majority of these are running outboards so yours will be pretty special. LS Motors are certainly the future of powering pleasure boats and GM's new LT4 with 650 HP would be an excellent choice in your boat or a 32DW. With a pair of 540 hp Merc blue motors he said the 32 would run 124. With your lighter LS derived power plants 124 shouldn't be a problem. He also told me to apologize because he truly didn't know what the X dimension and height of the drives were on these boats as he's focused on the running surface design and not on the setups !!!! Keep those pictures coming !!!
  14. Thanks bor thanked for this post
    Likes bor liked this post
  15. #41
    Sep 2007
    the netherlands
    After a few busy weeks at work finally had some time to go on whit the allu engine mounts hope to finish them in the next week , plan is to put engines on a 3 ft alluminium rail so we can shift whit them forth and back to find a sweet spot .
ID:	348481Click image for larger version.
ID:	348482Click image for larger version.
  16. Likes noli, Scream And Fly, NICE PAIR, tmoore liked this post
  17. #42
    Discovery Bay, CA
    Quote Originally Posted by MeCapnDave View Post
    Not saying this new rig isn't going to run mid 120s, but do realize that a 32DW is a much faster hull with the same power than a C306. I think this is a great project, and I'm looking forward to seeing the results! I agree with CapnDave, keep the pics and info coming!
  18. Likes bor liked this post
  19. #43
    Jul 2015
    NC/TN/KY
    Man you are doing it freestyle Armand! Good for you. Wish I could fabricate stuff and had your shop here. Looking forward to your next visit to the US or maybe the wife and I can come see you somtime.
  20. Likes Scream And Fly, bor liked this post
  21. #44
    Sep 2007
    the netherlands
    Quote Originally Posted by Rayzor View Post
    Rayzor , We will see what happen It doesn t have to go mid 120 , I want to have a light weight easy to tow cat that handle some nasty water we can get here on the inland lake most of the time will be cruising from town to town and there are not many 100 + mph boats here so probably she will be one of the fastest if some one want to try
    like you say we will see what happens when ready and play whit some propshaft heights and weight distrubition .
  22. #45
    Sep 2007
    the netherlands
    One way or another we will get a beer somewhere together ! You and your wife are more then welcome here as well !
  1. I started painting and rigging Joe Perog's STV River Racer today
    By WILDMAN in forum General Boating Discussion
    Last Post: 08-13-2016, 04:47 AM
  2. Just started painting and rigging a new 2015 21ft liberator cat
    Last Post: 10-29-2014, 05:51 PM
  3. Finally started rigging.....
    By baja200merk in forum General Boating Discussion
    Last Post: 05-28-2013, 11:04 PM
