Results 1 to 14 of 14
    Feb 2012
    Prospect, KY
    Clogged Fuel Line??? Difficult to pull fuel through fuel line.
    The ball seems to work. It does pull fuel and pump it to the fuel pump. But not very much. It's a new ball. But when I press it in it likes to stay in.
    Tried to Linda Lovelace the line myself and found it to have a significant amount of resistance.
    If there was an air leak then it would pull air and inflate the priming ball. I removed the fuel tank cap to see if it was a vent issue but still having difficulty getting it to allow fuel to come out.
    Got any suggestions on what I can do or check?
  2. Likes rgsauger liked this post
    Dec 2012
    tn
    Pinched, twisted or folded fuel line- I had one get pinched under the floor-
    Anti-siphon valve clogged
    Has it been sitting up?
    Also had a gas line de-laminate inside-
    Can you get to tank outlet fitting?
  4. Thanks supervetteracer thanked for this post
  5. #3
    Jun 2009
    central minnesota
    anti siphon valve(last fitting on tank)remove ball/spring/ballseat from inside of hosebarb fitting. clogged pickup tube in tank..if you have old gray merc fuel line (red printing )replace it-th
  6. Thanks supervetteracer thanked for this post
  7. #4
    Feb 2012
    Prospect, KY
    Working in a very tight area to try and get to the anti siphon part. Can't seem to get a 1 1/4 wrench to grab at thsi angle. Guessing I need to remove this assembly and check it.
    Aug 2004
    Venice, Florida
    If you have the grey colored fuel line get it all out of the boat. It is not ethanol safe and has caused a lot of problems. The inside of the hose breaks down and cloggs everything up.
    21' Paramount
    Mercury 300 Promax
  9. Likes tux974 liked this post
  10. #6
    Jul 2015
    NC/TN/KY
    If your engine has a VST tank on it (Merc) Promax+ check it for debris in it and/or just go ahead and drain it and clean it out once you drain your fuel line and replace it.
    I am going back with a new squeeze bulb and Trident Barrier Lined A1-15 Fuel Hose USCG approved - 3/8 Inch fuel line and making up my own new setup to length. Hopefully when I have it out, I can shoehorn and fish my SC1000 connectors through the tube.
    I hear the best line to use is the blue stuff Hoser sells.
  11. #7
    Jun 2009
    central minnesota
    have had nothing but problems with all primer bulbs EXCEPT-- BRP EVINRUDE brand-- install at least 25 every season--install with arrow pointing up-th
  12. Likes delawarerick, rock, Baja170 liked this post
  13. #8
    My Bet is with Chris. Ethanol has deteriorated the fuel hose.
  14. #9
    Jul 2015
    NC/TN/KY
    Quote Originally Posted by mn808gade View Post
    I wish this thread would have been posted a couple days earlier, I got a Moeller brand coming.
  15. #10
    Jul 2015
    NC/TN/KY
    OK just got in the BRP brand yesterday. Hope to get back working on the boat this coming week. Thank you.
  16. #11
    No grey stuff, Quicksilver primer bulb with arrow pointing up has always worked well for me!
    Jul 2015
    NC/TN/KY
    I like that blue hose you run. That is the awesome stuff. When I go through the Shadow next, I will be using that. I used the Trident A1 USCG approved stuff in the Intimidator next go around with it, I get the blue as well.
  18. #13
    Quote Originally Posted by Baja170 View Post
    You can use the black stuff red stripe just as good and save a few $.
  19. #14
    Jul 2015
    NC/TN/KY
    That is what the Trident is, USCG approved. No auto part house High Pressure FI hose I have seen is USCG approved.
  1. Mercury Tech: Best fuel pump location and fuel-line set-up for my HST
    By 15 Mustang in forum Technical Discussion
    Last Post: 06-16-2009, 07:16 AM
  2. Fuel Return Line - Rigging New Fuel Pump Setup
    By Hydrasports205 in forum Technical Discussion
    Last Post: 06-17-2005, 07:06 AM
  3. Fuel Line Size & Fuel Filters
    By Liberator21 in forum Technical Discussion
    Last Post: 09-26-2004, 08:50 PM
