Results 1 to 15 of 16
Thread: 2.5 245 vs PM vs Prostock
04-11-2016, 11:13 AM #1
5000 RPM
- Dec 2002
- jonesville, La
- 717
- 11
- 83
Looming to get away from nic motor, hate to use it as tow boat, still want my speed and looking for longer engine life, I live on large lakes and can stretch it out for miles, but looking for all around fun, maybe ported promax or ported 200, or pro-stock type, maybe sell or trade my motor, what do the pro's think? Oh its on a SS allison
04-11-2016, 11:26 AM #2
I've thought about picking up a wounded 260,and doing six steel sleeves and a set of vertex pistons.Spend the time to dial in the cooling,or run on a two piece plate with stats and keep the rpms in the low 7000 range.Just mite last a long time----Or maybe not
04-11-2016, 12:14 PM #3
5000 RPM
- Dec 2002
- jonesville, La
- 717
- 11
- 83
Well I thought the same but was pointed out why use a nic block when it's cheaper to port or resleave a fishing motor, I'm not in the oilfield anymore so I can't really afford the high maintenance of nic
04-11-2016, 12:52 PM #4
If you aren't trying to run a class and can do whatever sell the nic block only and put everything on the promax block.
Very close in performance without the high dollar nic, pistons and rings IMO.
tux974 liked this post
04-11-2016, 12:55 PM #5
Does not cost any more to put steel sleeves in a nic block than a steel one,plus there would be very little port work to do. Just use preported sleeves, and trim them up after the install.If you were going to port and resleeve all six in a fish motor.I think that would cost more than six steel sleeves in a 260.
04-11-2016, 01:04 PM #6
5000 RPM
- Dec 2002
- jonesville, La
- 717
- 11
- 83
Well I could sale my nic motor and build what I want, nic is in good shape, no welds,bone stock, cc reeds @ spacer,and would have a long lasting motor
04-11-2016, 01:14 PM #7
Subscribed, ive always heard people talking about this and want to learn about it myself
Modded Hydrostream Vking
Hydrostream Vking
Hydrostream Viper
Sold, Hydrostream Vector, Allison xb2002
04-11-2016, 08:53 PM #8
im with ya pete......been debating this for a while.....i agree with what outasite said though about less work using 260 block.
friend of mine said he steel sleeved a 260 of his and was charged about 250 a hole...that adds up quick but then again the rings he runs now only cost about 100
definitely cheaper buying a ol' 200 block than even a scuffed up 260 block....
ive also thought it might be fun working on a 200 block myself ...give me some "garage beer time" activities....like i need any more..............
04-11-2016, 08:54 PM #9
also heard the later style 200 blocks had same exhaust chest as 260/225pm??????
04-11-2016, 11:38 PM #10
Don't kill a perfectly good Nic block, get 225 Pro Max motor. The put out low to mid 240hp stock, few tweaks and your good to go.
04-12-2016, 06:22 AM #11action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
04-12-2016, 06:42 AM #12
I'm with you Dave. The 225 Promax is absolutely the best option from the start....sticking with a factory setup makes everything downstream much easier and predictable....and they run great.
Now if you are all tooled up and the object is to make a pile of metal shavings....then have at it.Go Time
26 Regulator twin 250 EFI
04-12-2016, 06:56 AM #13
If your looking to plug and play,then by all means 225 pro max all the way! BUT if your thinking of a builder,What I suggested was a "wounded"260 block, not a perfectly good one.Taking a 260 that needs a renic, and has one or two gouged holes that needs a new nic sleeve or two,may not be the best choice to turn back into a full blown 260,but could serve as the perfect platform for a steel bore conversion.JMO
04-12-2016, 09:28 PM #14
Late EFI blocks have a good port but its still short of a promax and 260. Fishing chest is lacking on all of them when compared to promax/260.
The difference in the angles behind the liner greatly affect where the motor makes power. This is why MOST "260 ported" steel motors dont twist like the factory nic motors even with the same chest and front. THe porting takes tons of time and if you match the heights or put 260 spec sleeves in a steel motor yea it runs better but.....Last edited by baja200merk; 04-12-2016 at 09:33 PM.
Dave Strong liked this post
04-13-2016, 09:49 AM #15
5000 RPM
- Dec 2002
- jonesville, La
- 717
- 11
- 83
I think I'm going to sell my powerhead and get a promax, what should it be worth? I figure 4k - 4.5k, NIC is good I think maybe original, 92 model, no welds all stock, comp 138-144 cold, all cold readings CCR and spacer, lightweight flywheel,
Mercury Tech: Promax vs 260 vs prostock
By 90 5.0 in forum Technical DiscussionReplies: 27Last Post: 04-08-2016, 06:10 PM -
2.5 200 xri prostock motor rpm issues
By tcrabtree in forum Technical DiscussionReplies: 12Last Post: 06-05-2010, 08:30 PM -
odba prostock
By shawnjetton in forum Racer's HangoutReplies: 0Last Post: 01-10-2008, 08:03 AM -
ProStock, ODBA
By LARRY D in forum General Boating DiscussionReplies: 4Last Post: 03-27-2007, 07:27 PM -
Mercury Prosrock..prostock cowls??
By Ilovespeed in forum General Boating DiscussionReplies: 0Last Post: 10-10-2002, 10:14 PM
