Results 1 to 9 of 9
    Feb 2012
    Prospect, KY
    Is this an electric pump?
    Having issues with my 94 Johnson 120 V4 suging. Sometimes it runs fine, other times I have to pump the fuel ball to keep it on plane.
    Was thinking that it may be a bad fuel pump. Been researching about running electric fuel pumps and from what I've been reading from "normal" boat people. lol (As opposed to you triple digit loving screamandfly crowd) they are against it. Say that the mechanical pumps are more reliable etc.
    Then when I removed my pump I found these wires and what looks like could be an electric motor on my stock pump. Can you tell by this picture?
    Attached Thumbnails Attached Thumbnails 20160408_183941.jpg   20160408_183935.jpg
    Feb 2012
    Prospect, KY
    And do you know why there is a shradder valve on this carberated motor that hooks to my fuel pump?
    I might very well be mistaken, but isn't that a VRO pump?
  4. Likes supervetteracer liked this post
    Jul 2013
    Schrader valves are usually for an easy tap for a test pressure gauge.
  6. Thanks supervetteracer thanked for this post
    Feb 2012
    Prospect, KY
    It is, or was, a VRO. It started acting up last year and I sealed it off and went to pre mix. Are you implying that the oil pump is electric and the fuel pump is not?
    minocqua, wis
    yes it is file 13
    Dec 2001
    Sunbury, Pa
    That is a factory VRO pump and the wires are for the alarms, The Valve is a maintenance valve on the enrichener to make it easier to fog it or run engine tuner through it.
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
  10. Thanks supervetteracer thanked for this post
    Likes Slimm, supervetteracer liked this post
    Central, PA
    Riverrat is 100% correct
  12. Likes supervetteracer liked this post
  13. #9
    lindsay on. canada
    Riverrat is correct , there is a replacement pump that has no oil capability you do not save much $$ but no need to buy a oil pump if you are wanting to premix ........
  14. Thanks supervetteracer thanked for this post
  1. should i go to electric pump
    By 200VEGAS in forum Technical Discussion
    Last Post: 08-15-2011, 02:46 PM
  2. electric pump ?
    By daytrader in forum Technical Discussion
    Last Post: 08-08-2006, 09:50 AM
  3. Replies: 6
    Last Post: 05-12-2005, 02:21 PM
  4. electric fuel pump, through factory pump, or by pass?
    By WATERWINGS in forum Technical Discussion
    Last Post: 06-02-2003, 11:38 AM
  5. Electric Fuel pump-vs- stock pump
    By B.Mac in forum Technical Discussion
    Last Post: 10-11-2001, 03:49 PM
