Results 1 to 15 of 35
Thread: 250 Pro XS sleeves turning
04-03-2016, 08:34 PM #1
Supporting Vendor
- Jun 2008
- Maryville, Tennessee
- 1,019
- 28
- 28
- 49
- 258
250XS Sport sleeves turning
Bought a motor knowing it had a sleeve turned. Low hour rig. Come to find out two are turned and it had already been down once before due to a sleeve being turned enough to catch a ring. What's up with these motors??
Dave Hensley
1986 XR2002 /12" Mariner and string steering
18' Pugh Hydro
1992 XTB-21/225 ProMax
The barn is emptying out!!!
04-04-2016, 03:28 AM #2
6000 RPM
- Oct 2003
- LAGRANGE, IL
- 1,277
- 11
- 14
We had a brand new 225 Opti a few years ago. Turned sleeve. Factory replaced the whole powerhead under warranty. How old is this block? Have you asked your dealer to contact Merc Tech Service?
04-04-2016, 05:56 AM #3
Supporting Vendor
- Jun 2008
- 1,019
- 28
- 28
- 49
- 258
This block is a 2011. Already had work done on it when I got it. It is a 250 XS Sport.It has at least three sleeves with issues. Two turned now and looks like one that had turned before and was replaced.
Dave Hensley
18' Pugh Hydro
04-04-2016, 07:52 AM #4
Like any aluminum block with steel sleeve's in it . Need to warm up a little before you get on the gas ...
04-04-2016, 08:45 PM #5
Sad thing is it would be so easy for the factory to make the sleeves with a tab or make the block with tabs in the bottom to keep them from migrating around. I have pins in the bottom of my omc just in case. Dave
04-04-2016, 08:56 PM #6
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
YEP i know all bout it
here is what i did, i sent it to my machine guy and had him remove all sleeves because there was not enough interference between sleeve and holder
i had it bored out for oversize sleeves he added more interference it never happened again plus i bought six new advance sleeves with the most aggressive porting available. but mine was a efi
04-05-2016, 07:30 AM #7
Supporting Vendor
- Jun 2008
- 1,019
- 28
- 28
- 49
- 258
I think this is the only obvious fix. I have had cast sleeved 2.5 Drag motors I did with .005" interference fit turn 10,300 rpms with 240 PSI cranking compression and never turned a sleeve. Just wondering too if not having the head gasket ring seal bearing on the sleeve itself has something to do with it. I have seen them pinned by machining in a hole that catches the block register and sleeve and I have seen them installed using Loctite retaining compound with decent results. Best fix is a .005" interference fit. On an Opti I don't know about messing with port height. Probably better to stay stock??
Dave Hensley
18' Pugh Hydro
TEXAS20225 liked this post
04-05-2016, 09:19 AM #8
04-05-2016, 09:31 AM #9
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,633
- 21
- 270
- 219
- 524
- 5 Post(s)
Tighter fit also allows for better heat transfer.
04-05-2016, 12:01 PM #10
Supporting Vendor
- Jun 2008
- 1,019
- 28
- 28
- 49
- 258
Glue?????? Hmmmmmm.......do tell more.
Dave Hensley
18' Pugh Hydro
04-05-2016, 12:47 PM #11
04-05-2016, 03:13 PM #12
04-05-2016, 06:29 PM #13
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
no glue
just good machine work there is no good heat transfer with out sleeve making full contact with holder
04-05-2016, 06:35 PM #14
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
this is why some folks keep popping the same hole after boring it out to.015 then .030 then boom again same hole
james perry is so good on this he heats up my blocks with the holes up if he see's a bunch of goop in the floor after heating it up!!!! its well there must be a space between something where did this oil come from so he pulls it and guess what space behind sleeve 6-9 thousandths out of round so over size sleeve i can say this since he has done this for me in the last 3/4 years zero blown motas knock on wood
04-05-2016, 07:00 PM #15
- Jun 2007
- Singapore/Melbourne/Italy
- 9,384
- 1082
- 421
- 4805
- 2207
- 9 Post(s)
how much interference for an OMC sleeve?
2006 250xs new powerhead
By shortshaft in forum Technical DiscussionReplies: 10Last Post: 08-03-2008, 05:23 AM
