Results 1 to 14 of 14
Thread: Lost reverse
03-26-2016, 09:13 PM #1
Lost reverse
I've got a 2.5 lower with Bob's cone I bought from a guy on here late last summer. Went out today for the first time this year after changing oil in the lower. Ran 25 miles or so with no issues. Got back to the landing and had no reverse. No warning whatsoever, no grinding, jumping out of gear, etc. Forward still works great, no noises. Checked the linkage and everything looks normal topside-the shift lever goes all the way to the rear and nothing, prop spins freely. Just wondering what happened and how bad $$ it is. Any ideas? Every other lower I've had go bad gave plenty of warning before crapping out-except a CLE with locked up driveshaft being. Thanks for any help.
Allison GT20
ProMax/260
03-27-2016, 06:59 AM #2
5000 RPM
- Apr 2005
- Canada, East!
- 518
- 10
- 11
- 304
- 50
- 2 Thread(s)
Disconnect the shift cable and see if you can shift it into reverse by moving the linkage to rule out the cable & control throw.
If you can't shift it by hand drain the gear case and see what comes out.
pointer
jmadisonbiii thanked for this post
jmadisonbiii liked this post
03-27-2016, 08:31 AM #3
Supporting Member
- Jul 2013
- California
- 1,699
- 26
- 84
- 113
- 374
Is this the first time trying reverse in this gear case?
Typically when reverse goes it will clatter when you put in reverse as the dogs are dancing over each other and not engaging.
Never saw one with no noise in reverse and still shift in and out of forward. Are you sure you timed the shift shaft to the lower unit correctly?
Take a look and see if the bearing carrier nut loosened up allowing the bearing carrier, along with the reverse gear, to move back away from the dogs.
03-27-2016, 09:25 AM #4
03-27-2016, 09:58 AM #5
As Onetime said if the bearing carrier nut slipped or backed out this will happen but normally ratchets.
03-27-2016, 10:02 AM #6
Yep, the big bearing carrier nut backed out. Only about 1/4" of hub showing, some water in the oil, and oil in the hub around bearing carrier. A little bit of metal on the magnet, no more than usual. On closer inspection, the bearing carrier nut had a crack all the way through, I guess that would do it. Just to be sure, I tightened it a couple of turns and sure enough it was trying to catch when I rotated the prop. Guess I'll order a new nut and may as well put a seal kit and water pump kit in while am at it. I'm hoping no permanent damage as I never heard grinding, no chunks in oil, etc.
Allison GT20
ProMax/260
03-27-2016, 10:08 AM #7
Hopefully the threads in the case did not get damaged.
03-27-2016, 11:31 AM #8
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
case may be swollen and nut wont stay tight, ive had them pop out after torquing it down they have to be 225 minimum torq or it will spin carrier which it probably has already
good luck
03-31-2016, 06:01 PM #9
Got the carrier out today, it had spun. Some of the threads, and the keyway look pretty shallow/washed out. I installed everything and tightened the nut,seems like it wants to hold, and everything seems to be working properly. Haven't torqued it down yet though. What about loctiting the carrier nut and/or pinning the carrier?
Allison GT20
ProMax/260
04-01-2016, 11:20 AM #10
Loctite and pinning might help but in my experience Loctiting and pinning are just band aids putting off the inevitable. Hopefully they get you another season but I would start preparing to either have case repaired or replaced. Good luck.
RockTeam Junk
04-01-2016, 11:52 AM #11
The tell tale will be when final assembly comes and you try to fully torque the bearing retainer nut. Some shops have a thread chaser for the housing threads, we have 2 styles. Might see if you can find a shop with a thread chaser and get them to clean the threads. At that time a tech with experience can give you a good opinion if it's even worth trying to use the housing.
Good luck.
04-01-2016, 03:34 PM #12
04-01-2016, 06:31 PM #13
Thanks guys. This will only be a temp, I hope. I won't run it too hard.
Sent my CLE off today to get repaired-driveshaft bearing. If the nut holds, I will keep this one for a spare. I wouldn't sell this thing to anybody.
Allison GT20
ProMax/260
04-01-2016, 09:43 PM #14
Yep..it can be "fixed". My take here as done it my Switzer XS 1500 1974 (new, and J block) with a surface 14x28 cupped SS prop. That slapping prop beat the hell out a couple rear carrier case. But DO NOT USE any Loctite, 4200/5200 3M! Just something to seal L/U water intrusion, like "Boat life" caulk..?..forgot and slam it home for a good seal, easy torque and then drill and tap 4 holes into the carrier, 1/4-20, or bigger and set screw it. And won't hurt to add outer a couple worm gear hose clamps. Do that, easy on reverse, and ..well?... cheap fast fix. Wish the best here!
no reverse on 225 promax
By allyrunner in forum Technical DiscussionReplies: 19Last Post: 07-25-2009, 06:24 PM -
Cat with twin outboards or Cat with single I/O ?
By PORT in forum General Boating DiscussionReplies: 96Last Post: 12-17-2008, 01:05 PM -
Sport Master = No Reverse
By 302sr1 in forum Technical DiscussionReplies: 3Last Post: 09-10-2007, 04:21 PM -
Sportmaster gearcase lost forward???
By STV_Keith in forum Technical DiscussionReplies: 13Last Post: 05-07-2007, 08:58 AM -
No Reverse
By wideopen23 in forum Technical DiscussionReplies: 4Last Post: 01-08-2007, 09:58 AM
