Results 16 to 30 of 42
03-21-2016, 12:34 PM #16
Screaming And Flying!
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Baseboard heat is a pig on kwh. I can spin the meter off he wall . I can do 300 kwh in a weekend no problem. Maybe you had a bypass feed to the hot water take before the meter switch and then they hooked you up .
03-21-2016, 01:16 PM #17
03-21-2016, 01:19 PM #18
03-21-2016, 01:34 PM #19
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Oh , gas hot water and heat. GO through the box and see what's drawing. Phantom power suckers like new HD TV pull 15W when off , computers on standby , stereo amps left on, plug in CO detectors , if you have enough they can add up to a couple or more amps running 24 /7 .
03-21-2016, 10:09 PM #20
03-21-2016, 11:02 PM #21
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Some of the old dial meters couldn't read the real low amp draw , so I was told. Not sure if that is accurate . Hit the thing with a bat and call them to come and replace it.
olboatman liked this post
03-22-2016, 05:55 AM #22
03-22-2016, 08:29 AM #23
8000 RPM
- Sep 2006
- not here
- 3,391
- 221
- 431
- 445
- 695
03-22-2016, 09:17 AM #24
03-22-2016, 11:29 AM #25
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
All new smart appliances with smart phone apps , they all suck extra on top of the motor. The light in the fridge and in the garage and in the oven . UV light water . Someone hiding an electric blanket.
03-22-2016, 02:19 PM #26
They probably don't read the meter every month, so for most months they estimate consumption based on past usage.
Then they drove by and read the meter this month, and it turned out their estimates were too low. The additional 400 kWh may be 400 kWh over 6 months, i.e. 67 kWh per month.Markus' Performance Boating Links:
03-22-2016, 02:23 PM #27
03-22-2016, 03:17 PM #28
8000 RPM
- Sep 2006
- not here
- 3,391
- 221
- 431
- 445
- 695
Past bills will tell you if they estimated. My National Grid bill even shows monthly usage for the past year. They read mine every month.
'03 21ft Inboard skiboat V-8
'70 14ft Winner, 90hp Merc
'22 21ft Inboard skiboat electric
03-22-2016, 05:06 PM #29
- Feb 2015
- Ontario
- 8,124
- 205
- 324
- 1938
- 2015
Get a note pad and count your kWh use on a daily , hourly for a week. Then smash it with a bat and get a new one.
home made tunnel liked this post
03-22-2016, 05:31 PM #30
Team Member
- Jul 2015
- NC/TN/KY
- 1,056
- 94
- 104
- 1322
- 492
Our meters here phone home and are exact every month. I thought all power companies do that now and I live out in the sticks. It used to use my land line, now it does it some other way since we don't have a land line. Meter readers used to come but I have a gate on my driveway and live on a mountain so they can't get in. That is why they installed the kind that does not need a reader each month to begin with. Surely NC in the country is not that more advanced than everywhere else.
Mercury Tech: Hour Meter question
By 4Speed in forum Technical DiscussionReplies: 7Last Post: 09-01-2015, 06:48 PM -
Hour Meter hook up question
By BillR in forum Technical DiscussionReplies: 1Last Post: 01-03-2012, 08:42 PM -
Gaffrig Volt Meter Wiring Question
By tj309 in forum Electronics, Audio Systems, and WiringReplies: 2Last Post: 01-11-2006, 08:33 AM
