Results 16 to 30 of 38
Thread: Again..Yamaha 300hpdi pistons?
12-25-2015, 10:50 AM #16
Hpdi's are torque monsters and will spin to 6000 all day.
key to a good hpdi is proper breakin,filter services good oil and gas.
there is plenty of reliable power from these motors.
I prefer Wsm Pistons that are Teflon coated skirts, Pistons that drop the locating pins will have a deformed piston dome usually from lugging motor (prop to big)or poor fuel quality.have not seen these problem with the Wsm pistons.
reeds I like Chris Carson reeds with cleaned up cages
no spacer plate,as you can not take advantage of high rpms needed to see improvements
solid motor mounts,exhaust modification are good like to cut the liner out.
i would not cut heads unless you can run premium fuel.
biggest improvement is just clean up porting21 SuperBoat VF200 Yamaha SHO
Bender Clan member
Eroshibend Yamamoto
12-25-2015, 01:18 PM #17
Member
- Sep 2013
- Finland
- 55
Thanks!
what did you mean ,exhaust modification are good like to cut the liner out ?
-Should i leave powerhead stock,or litle porting exhaust holes upper?-Bobs tuner?-biggest improvement is just clean up porting?
Do you mean"clean up" all sylider air/exhaust holes? or only exhaust holes?
I have read positive efect lightweight flywheel,maybe i do this mod also.Last edited by Finman; 12-25-2015 at 02:34 PM.
P21 & 300hpdi
12-25-2015, 07:40 PM #18
Light weight fly is good,once you have the block apart you will see about cleaning up transfer ports don't raise any ports just a clean up,also check rod weights
Bender Clan member
Eroshibend Yamamoto
DoktorC liked this post
12-29-2015, 01:25 PM #19
5000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
Yes, I would call HydroTec. I bought a newly rebuilt 3.3L phase III that previously had the typical locator pin piston failure. I ran it for 5 years with relatively low hours and then had another piston failure. It has been rebuilt again by HydroTec. In both cases there was no sign of fuel or ignition problems. My understanding is that HydroTec is using another brand of piston now and they have not had a failure in 2 years. Clearly there is a problem with pistons used in the 3.3L Yamahas.
Excluding the piston issues, my 3.3L phase III has been great. I use mine for family boating, fishing, water sports. Sometimes with 6 people + gear in the boat. Just prop accordingly.
01-30-2016, 03:10 AM #20
Member
- Sep 2013
- Finland
- 55
01-30-2016, 03:24 AM #21
Member
- Sep 2013
- Finland
- 55
ok!
I cant belive how unfinised Yamaha block ports had! I clean all ports
My setup:'
*WSM pistons.
*Block ports clean.
*Bobs tuner.
*BB throthle body(1 3/4" -> 2"plates).
*CCMS reed valve.
*1 1/4"Intake spacer.
*Light weight flywheel.
*Rods/pistons weight balance.
Heads will be stock,because sheap regular gas 90(USA, same gas europe is 95.okt). 1.75$/gallon.Last edited by Finman; 01-30-2016 at 11:10 AM.
P21 & 300hpdi
01-31-2016, 12:08 AM #22
5000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
post # 16..-th
Superbender liked this post
01-31-2016, 09:59 AM #23
Member
- Sep 2013
- Finland
- 55
01-31-2016, 10:17 AM #24
01-31-2016, 10:45 AM #25
Member
- Sep 2013
- Finland
- 55
ok
If i leave s.plate off, how about all the rest setup...
*WSM pistons.
*Block ports clean.
*Bobs tuner.
*CCMS reed valve.
Does anybody know engine balanse;are crankshaft&rods&flywheel balansed together? or everything separate?Last edited by Finman; 01-31-2016 at 10:51 AM.
P21 & 300hpdi
01-31-2016, 10:48 AM #26
Deadly!
The spacer plate doesn't hurt (much) but it doesn't give you anything at all. It may take away some bottom and mid but it's hard to tell because the motors make a tonne of power there.'08 SRV
Yamaha 3.1 Phase III
01-31-2016, 10:57 AM #27
Superbender thanked for this post
01-31-2016, 11:05 AM #28
Member
- Sep 2013
- Finland
- 55
P21 & 300hpdi
02-01-2016, 06:38 PM #29
02-01-2016, 06:55 PM #30
HELP NEED YAMI TECH OR SOMEONE WHO KNOWS 05" Yamaha 300HPDI lower unit question
By pfrae in forum Technical DiscussionReplies: 11Last Post: 09-04-2012, 01:40 PM -
yamaha 300hpdi to 2.5 offshore
By nates-yamaha in forum Technical DiscussionReplies: 0Last Post: 10-02-2010, 11:28 PM -
Yamaha 300hpdi....
By JAYROCK in forum General Boating DiscussionReplies: 10Last Post: 12-14-2005, 09:43 PM
