Results 1 to 15 of 16
    Sep 2009
    n.y
    hydraulic steering fluid options??
    anyone have any low cost alternative options with hydraulic steering fluid??? other than the pricey teleflex stuff thanks .
    24-Skater "substitute found"
    Mineral based hyd fluid, do not use petroleum based hyd fluids.
    John, your steering equipment is much too good and valuable to chance anything else. A few extra $'s for good fluid is well worth the piece of mind. I buy it on line, much cheaper...JMPO!
    I know, it feel like your buying gold in a bottle......
  4. Likes NICE PAIR, Frank Molé liked this post
    Moline,Ill
    I've always used Boss snow plow fluid in mine, same 5606 mil spec, usually around $25 a gal.
    is gone
    Jul 2002
    FT WORTH, TEXAS
    buzzin x2 any hydraulic supply house will have it thats what i paid 25.00 a gallon exact same specs
    Central Florida
    From their website
    What kind of oil should I use in my SeaStar system?
    Recommended oils for your steering system are: SeaStar Fluid, P/N HA5430 (1 quart), HA5440 (1 gallon). The following brands are acceptable: Chevron® Aviation Hydraulic Fluid A, Esso® Univis N15 or J13, Mobil® Aero HFA, Petro Canada Harmony HV115 (in Canada only), Shell® Aero Fluid #41, Texaco® HO15 and other fluids meeting MIL SPEC H-5606-G.
    So any aviation "5606" oil should work and they will be dyed red.
    Or essentially any ISO 15 hi viscosity anti wear hydraulic fluid. If you want the amber/clear stuff try Shell Tellus 15 from any industrial supply place. But may be hard to find in less that 5 gallon pail.
    Central Florida
    Quote Originally Posted by Dave Strong View Post
    Did you mean to type synthetic? Because mineral and petroleum are the same thing.
  9. #8
    Quote Originally Posted by BarryStrawn View Post
    No, was getting at what alot of people think is a replacement for hyd oil. ATF, put that in the system and your overhauling the system.
  10. #9
    Gothenburg, Sweden
    The mil spec stuff above, or the kind of fluid used on old Citroen cars.
  11. #10
    longisland
    I use clear power steering fluid from the auto parts store never gave me any issues
  12. #11
    Big Rock, IL / Eagle River, WI
    It's not cheap...but less expensive than telelex and still the correct fluid for seastar systems
    AeroShell 31 about 40.00/gal online or your local airport
  13. #12
    Sep 2009
    n.y
    thank you guys very much !! MERRY CHRISTMAS everyone!!!
  14. #13
    Long Island N.Y.
    Quote Originally Posted by jas638 View Post
    J,
    just buy the best, youll feel better when you turn the wheel your boat looks like a peice of jewlery...........
    21 Tuff, Mercury 300X
  15. #14
    Sep 2009
    n.y
    Thanks Dirk ,gonna send you some pics.
  16. #15
    Jul 2002
    LI NY
    Jas i buy Kendall hyken Glacial Blu....it meets the seastar spec and is designed to work properly under severe cold temps....i find the steering doesnt start to feel like a brick when the weathers cool....i will also say that there are tons of boats running around with ATF in there systems with no issues....In the thousands of boats i have worked on in my 20+ years as a merine tech i have never seen a steeri g system fail because of the wrong oil....
    1984 28 ghost twin 200 Yamah ProVs (SOLD)
    1997 21 Superboat Legend 250 VMAXXX (SOLD)
    2001 25 Concept CC 250EFI (SOLD)
    2002 24 Superboat Step 250EFI (SOLD)
    1997 21 Checkmate Pulsare 200EFI Merc (Beater Boat)(SOLD)
    1994 20 Hydrasport 225 Optimax (SOLD)
    1998 27 progression Twin 225 Mercs (SOLD)
    2005 23 Kryptonite 300 Promax (SOLD)
  1. Seastar Hydraulic Steering fluid substitutes?
    By Wolverine in forum Technical Discussion
    Last Post: 05-27-2017, 02:26 PM
  2. jack plate hydraulic fluid vs. steering??
    By Fassster in forum Technical Discussion
    Last Post: 08-15-2012, 08:57 PM
  3. Leaking hydraulic steering fluid on my 24 skater..What to do...
    By Viper GTs in forum Technical Discussion
    Last Post: 04-19-2010, 07:47 PM
  4. Hydraulic Steering Fluid
    By Pro300x24LD in forum Technical Discussion
    Last Post: 05-22-2007, 09:57 AM
  5. hydraulic steering fluid???
    By godspeed in forum Technical Discussion
    Last Post: 02-14-2006, 05:38 PM
