Results 1 to 15 of 49
12-08-2015, 04:27 PM #1
Why are ETec G2 H.O. Motors selling for less than the older Etec H.O.'s ?
example
2015 Evinrude E-tec 250H.O. 15K
2015 Evinrude E-tec G2 250H.O. 13K
Both with comparable hours and condition..
Is there a problem with the new G2 motors?
12-08-2015, 06:31 PM #2
12-08-2015, 06:55 PM #3
Member
- Oct 2013
- Ontario, Canada
- 48
12-09-2015, 12:51 PM #4
Member
- Nov 2015
- Chicago
- 92
- 39
- 29
From my observation, G2 are good.
But I had to buy them a new interface - here in Poland big cost ( 900$ ! )
12-09-2015, 12:55 PM #5
12-09-2015, 03:46 PM #6
Skills required to work on a G2 are about them as a G1... Gotta have a basic understanding of the engine, diag, special tools, and access to dealer support website (bossweb) also helps.
I personally haven't seen any used G2's in my area/market yet alone what they are going for. But as far as buying a brand new G2, the base price between a comparable hp G2 and G1 engines aren't to far apart. The killer is rigging cost. G1's use push-pull shift/throttle, use the same boat harness since the mid 90's, you can hook them up a most analog marine guages... G2's however are all new and its all digital($$$$). They use their very own boat harness, electronic shift/throttle (control boxes/foot throttles are $$$), you have to use one of the available touch screen displays($$$) in order to be able to use all the different engine functions... So in order to repower a boat (even it already has a Johnrude on the transom) all the rigging gotta be changed, and its gonna cost a few bucks! So maybe that is effecting the resale on these new G2's? I know the rigging costs has deterred a few from buying new ones.Dan Cario
1994 STV Mod-VP w/225HO Ficht Evinrude
1987 22' Velocity w/225HO Evinrude E-Tec
12-09-2015, 04:02 PM #7
Nice looking sig photo Baja16
oldschoolltv liked this post
12-10-2015, 07:37 PM #8
New technology is always interesting and we all like the possibility of better gas mileage along with performance. But until the ETEC gets enough people involved (corp. or independent) to offer more HP upgrade parts to be accessed and at reasonable cost, I can't see many going this route over Yamaha and Mercury.
1990 22' Activator Yami HPDI 300-sold-86.4
1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
1982 21' Superboat 300merc-87
1990 22' Activator yami OX66 Vmax 250-84.2
1982 30' Scarab-twin 200 Merc-sold
1979 21' Challenger 300 Evenrude-sold
1979 21' Superboat 200 Merc-sold-72
12-10-2015, 09:21 PM #9
Supporting Member
- Jul 2004
- Connecticut
- 6,261
- 518
- 205
- 1074
- 1127
I really think that the cosmetics are going to take time to get used to. They are changing what people think an Outboard Motor should look like. You don't change 25 years of one look in a couple of years. Personally, I can't warm up to the cosmetics at all. I think the alien cowl is about the best looking lid ever but the G2 will be fine over time if it holds up to a beating.
12-10-2015, 11:37 PM #10
A long time friend in FL is a large Evinrude dealer, since the late 1980s. He has been one of the largest Evinrude repower dealers in FL for many years now. He echoes your sentiments Dan. His repower market will go away if all he has are G2s to sell. He still sells a lot of "G1" E-Tecs, but he has since taken on Tohatsu to shore up sales. I don't blame him one bit. BRP needs to listen to their dealers and listen to the market. Yamaha, Merc and Suzuki own the market. That's not the way it was less than two decades ago, if BRP ever hopes to get back to where OMC once was they need to sharpen their pencils. The market does not exist in a vacuum; it's had 15 years of "four strokes good and reliable, two strokes bad and smelly". A huge mountain to overcome.
tux974 liked this post
12-11-2015, 12:04 AM #11
Supporting Member
- Jul 2004
- Connecticut
- 6,261
- 518
- 205
- 1074
- 1127
12-12-2015, 10:07 AM #12Markus' Performance Boating Links:
rgsauger liked this post
12-12-2015, 02:17 PM #13
The problem with evenrude is they want nothing to do with hi perf
it is the biggest pain getting normal stuff mounts, steering,gear cases, stay with Merc21 Tuff, Mercury 300X
12-12-2015, 03:01 PM #14
Yes, even in some cases close to 6k... Their are a few options for the touch screen displays and accessories that can really add up. If you do run multiple engines, the cost per engine goes down because they all can get wired through a common network and the larger touch screen displays can handle multi-engine setups. That is one nice feature on Evinrudes ICON system if your rigging 2+ engines on a transom their usually isn't as much physical wiring. You have spend some time configuring the network buts its fairly simple once you do it a time or too.
Dan Cario
12-13-2015, 05:02 AM #15Markus' Performance Boating Links:
JWTjr. liked this post
OMC Tech: Etec 250ho-2 blown motors
By garygbnj in forum Technical DiscussionReplies: 2Last Post: 06-07-2014, 03:27 PM -
Difference between 2008 etec 200ho & 2011 etec 200ho??
By coojac in forum Racer's HangoutReplies: 2Last Post: 09-02-2013, 05:43 PM -
Etec cowling be modified to fit on older 3.0L omc
By RayburnRacer in forum Technical DiscussionReplies: 11Last Post: 01-30-2009, 03:49 PM
