Results 1 to 12 of 12
    Lake Seminole, GA/FL
    Land and Sea mechanical fuel injection
    Anyone have any info on the land and sea fuel injection system made back in the '80s
    pros and cons? OMC V6 setup ?
    Gothenburg, Sweden
    No info on that one, but as a general rule, Land and Sea parts rarely performed as advertised. The more complex the part, the wider the gap between reality and the Land and Sea catalog...
  3. Likes wtsjr66 liked this post
    Jan 2003
    aalsmeer
    why stay in the 1980,s
    when you can have a system from the 1893
    http://www.disa.it/pdf/01HystoryOfDieselFuelInj.pdf
    coal dust all the way more then enough coal to keep that outboard running for the next 200 years!
  5. Likes olboatman liked this post
    Quote Originally Posted by PanRonnie View Post
    why stay in the 1980,swhen you can have a system from the 1893 http://www.disa.it/pdf/01HystoryOfDieselFuelInj.pdfcoal dust all the way more then enough coal to keep that outboard running for the next 200 years!
    I can't stop laughin....and I thought I was cruel!!! Gary
    There is no intention of ever using it , on the shelf it will stay with other obsolete stuff !!!
    Lots of career opportunity for comedians out there on the Vegas strip or Screamandfly.
    send mercace a pm. I believe we have two setups in the shop and he was talking about running a set up on a mod vp motor. Best I can do
    Real vintage Algon mechanical on twins
    Thanks, Just looking for some history on this or maybe an old brochure photo, just for fun of course !
    Central Florida
    Quote Originally Posted by swamppanther View Post
    Just a basic constant flow system like Kinsler, Hilborn, etc. Pro is if you want to run alcohol or fuel. Also a very simple system. Con is the mixture control is not high precision compared to a well designed EFI or carburetor setup. Which doesn't matter so much with Methanol.
    phoenix, az
    Quote Originally Posted by BarryStrawn View Post
    Agreed. You can make mechanical injection work well on a two stroke. It can be difficult getting the barrel valve cut right, and also the bypass valves pressures set. They were great before EFI became as consumer useable as it is.
    Dec 2011
    Ludington michigan,on the shore
    Here ya go.Click image for larger version.
ID:	332285Click image for larger version.
  14. Likes FMP liked this post
    May 2021
    Minnesota
    Old omc fuel injection
    Hello, I was scurrying around and found this reply of yours to a fellow who looking for a fuel injection unit. just checking to see if that old unit is collecting dust or rust on a shelf somewhere in junk parts land.
    Thanks
    Aaron
  1. mechanical fuel injection?
    By hydroViper235 in forum General Boating Discussion
    Last Post: 06-28-2012, 08:13 PM
  2. Replies: 7
    Last Post: 01-28-2011, 08:21 AM
  3. Mechanical 2.5 fuel injection
    By RBT in forum Technical Discussion
    Last Post: 05-31-2008, 01:52 PM
  4. Land & Sea fuel injection
    By Robbie B in forum Technical Discussion
    Last Post: 05-02-2001, 04:06 AM
