Results 1 to 15 of 16
    Feb 2007
    Sydney, Australia
    Rinda Diacom Diagnostic Software
    I'm looking at buying one of these diagnostic packages but Rinda seem to be difficult to get answers from.
    Who is using this software?? What do you think of it?? And does anyone know if it's compatible with the newer type F150, F115 CT motors.
    I only need the outboard software so I'm not interested in the inboard side of it.
    Jan 2003
    aalsmeer
    Feb 2007
    Sydney, Australia
    Thanks for the link.. But I should of been clearer with my post. I only need Mercury specific software.
    Jan 2003
    aalsmeer
    ft pierce fl
    i have a rinda scanner. it works the same as a ddt. reads history, hours and codes. it will fire injectors and coils to test them. i have a cable for my optimax and for efi mercurys.
    Jun 2008
    Maryville, Tennessee
    Quote Originally Posted by davemvegas View Post
    Read their advertisements and it hinted that you could go in and change performance parameters. Fuel offsets but not actually curves? DDT software is tough to come by for the Smartcraft motors. If you have used both DDT and Rinda what has your satisfaction with the Rinda? Pros and cons? Thanks.
    Dave Hensley
    1986 XR2002 /12" Mariner and string steering
    18' Pugh Hydro
    1992 XTB-21/225 ProMax
    The barn is emptying out!!!
    Ft. Lauderdale, Fl
    The scan tool specs are here, looks like it will do them with the right cables/..... http://www.rinda.com/acro/Diacom_Engine_Support.pdf . as will the software for PC http://www.rinda.com/acro/Diacom_Engine_Support.pdf
    Ft. Lauderdale, Fl
    I use Rinda, been using it for the past ten years.....does everything I need it to do
    ft pierce fl
    Quote Originally Posted by LongShot View Post
    i have not used either one enough to compare the two. i use my rinda to look for code that is causing a horn to go off. also to set the tps volts at idle. it seems to have the same data as ddt for rpm and hour history. i am in the dark about either being able to reprogram fuel or timing of the pcm. it is also good for firing the coils and easily spotting the one with a weak spark.
    Feb 2007
    Sydney, Australia
    I'm happy with the functions of the Rinda software, but does anyone know if it's compatible with the new mercury 4 strokes?? I've heard they use a different platform. G3 seems to come to mind.
    Jan 2003
    aalsmeer
    Feb 2007
    Sydney, Australia
    That list tells me that it only supports 4 strokes between 2002-2010.
    Either the list hasn't been updated or it doesn't support the newer 4 strokes. With 2016 around the corner, it seems like the package is a bit dated...
  13. #13
    Jan 2003
    aalsmeer
    it says Verado 350 = the verado 350 is fourstroke and introduced in 2015
    https://www.mercurymarine.com/en/us/unleashed
    don,t know which engines you could mean unless the 400R
    http://www.mercuryracing.com/outboar...s/verado-400r/
    or 400 ROS
    http://www.mercuryracing.com/meet-the-new-boss/
  14. #14
    Feb 2007
    Sydney, Australia
    The engines in question are the 3.0L inline 4 150hp, the 1.7L 115hp CT (Command Thrust).
  15. #15
    South Africa
    Is the CT not a 2.1L engine?
    The 1.7L is the older verado derived NAL4 ( Naturally Aspirated L4)
  1. Diacom Marine Diagnostic Software
    By Wayne Cammidge in forum General Boating Discussion
    Last Post: 09-17-2013, 01:28 AM
  2. Rinda software
    By LongShot in forum Technical Discussion
    Last Post: 02-01-2013, 05:20 PM
  3. DIACOM Marine Diagnostic Software
    By cutwater in forum Technical Discussion
    Last Post: 10-20-2010, 05:07 PM
  4. FI diagnostic software
    By Action Marine Alaska in forum Technical Discussion
    Last Post: 05-05-2009, 12:45 AM
  5. Diagnostic software
    By flabum1017 in forum Technical Discussion
    Last Post: 02-09-2008, 10:23 PM
