Results 1 to 6 of 6
Thread: 2.5L Block Weld
    Aug 2003
    Onset, MA
    2.5L Block Weld
    Any idea what this might cost to have welded up?
    Nov 2013
    Oak Hill Fl.
    Getting mine done on two cly for $100.
    Although he wanted the sleeve out to do it. That was extra $
    No problem as I wanted them pulled so I can port the block any way.
    Torque a head down down on that side . Have the guy weld it from the bottom side only unless it's spider cracked out from the hole . put a little pre heat in it and use 4043 filler rod . Even done quickly , it's more than likely going to pull that cylinder out of round at the bottom .
    If you have a cylinder jack , be sure to put it in at the bottom. goes a long way in keeping it round .
    Use a set of bottom pressure stones to touch that cyl up and you should be good to go ... as long as the other side where the bomb went off looks good ...
  4. Likes Slimm liked this post
    Jun 2008
    Maryville, Tennessee
    Have seen those ground out to make sure there are no cracks running out from the hole and Kop Kote used to fill. The stuff is unreal and if you scuff up the area around the repair it will stay forever. I think you could build a block out of it! Chaz describes the best way to do it with weld. I use a round copper plate in the bottom of the cylinder and weld from back side. Betting that cylinder and one/two adjacent might already be moved a little.
    Dave Hensley
    1986 XR2002 /12" Mariner and string steering
    18' Pugh Hydro
    1992 XTB-21/225 ProMax
    The barn is emptying out!!!
  6. Likes Slimm liked this post
    Aug 2003
    Onset, MA
    Aug 2003
    Onset, MA
    here's the inside. Longshot . . . do you still think I can get away with using epoxy? I think I'll give it a try.
    I found this thread for A-788
    http://www.screamandfly.com/showthre...light=Kop-kote
  1. recomendations on who can weld a big hole in a merc 2.5 block
    By 88VTRocket in forum Technical Discussion
    Last Post: 05-19-2014, 06:09 PM
  2. jb weld on block
    By YELLOWSS in forum Technical Discussion
    Last Post: 10-15-2004, 04:19 PM
  3. Skeg: To weld or not to weld-
    By 1BadAction in forum Technical Discussion
    Last Post: 07-02-2004, 10:30 AM
  4. Help!!-How to remove a steel sleeve to weld block
    By Valeroman in forum Technical Discussion
    Last Post: 04-07-2003, 11:59 AM
  5. CRACKED BLOCK!!! Should I weld?
    By pirogue in forum Technical Discussion
    Last Post: 10-24-2002, 10:47 PM
