Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 52 of 52
  1. #46
    Aug 2012
    beaumont, tx
    Yep....pulled heads 2 trips ago cylinder was fine.....loaded a big boy in boat last trip...guess the extra heat got it
  2. #47
    Aug 2012
    beaumont, tx
    Found wood today after pulling divider
  3. #48
    Aug 2012
    beaumont, tx
    I've ran it twice a week for a month trying to diagnose problem.....never thought I'd have a cork in water way
  4. #49
    Aug 2012
    beaumont, tx
    Still have compression....no meltdown signs on plug. U seen em
  5. Likes tux974 liked this post
  6. #50
    Aug 2012
    beaumont, tx
    Think I'm gonna sell boat and get into low rider bicycles. ...NOT
  7. #51
    That's funny!
    Sorry to read about your findings and outcome! I'm sure you can save things if you get it to the correct person! James Perry would also be my suggestion.
  8. #52
    Jul 2002
    FT WORTH, TEXAS
    here is my unsolicited opinion on that hole if i was a betting man i would say sleeve holder 3/5 thousanths out of round or more and a standard od flanged sleeve was installed this will not work the heat will not transfer ive learned this the hard way out of my pocket when Jim Ruck was still driving up at his place i would suggest things as how i thought they should work he would set me straight, when he dropped off front line i moved to James Perry's shop totally he is way better then any one ive ever used he has told me things and procedures on resleeving i would not believe before but after 7 years and no blown motors or stuck pistons "EVER" i now am installing 6 new sleeves in every motor so everything i sell now is new standard bore it just my experience on eating bad machine work
  9. Likes texasvector liked this post
  1. 400R fuel burn
    By Rayzor in forum General Boating Discussion
    Last Post: 08-03-2015, 08:20 PM
  2. 250 xs ratio / fuel burn
    By Porketa in forum Technical Discussion
    Last Post: 05-23-2013, 06:52 PM
  3. How much fuel would a pair of early '90s 2.5s burn?
    By dba900 in forum Technical Discussion
    Last Post: 10-29-2009, 09:57 AM
  4. 300X Fuel Burn
    By BluFin in forum Technical Discussion
    Last Post: 06-07-2005, 08:53 PM
  5. 200 Pro Max fuel burn???
    By 87vantage in forum Technical Discussion
    Last Post: 11-15-2004, 09:00 AM
