Page 2 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 16 to 30 of 121
    Feb 2010
    li NY
    Quote Originally Posted by jasonpijanowski View Post
    That boat should run 105 with a 24 pitch prop if you get the motor tuned in...I bet you can go faster with a smaller prop then that 32...
    why would I want to spin the motor that high ?? And as far as tuning the motor right I kno what I'm doing guy
  2. #17
    Feb 2010
    li NY
    Quote Originally Posted by JWTjr. View Post
    When it's boats not political discussions, Cuda and I agree for sure. Straightening and sharpening the bottom is the oldest trick in the book, and the most effective. Sure beats spending thousands on mod motors that are more powerful yes, but so much less tractable and reliable.
    once I get another solid number I'm going to sharpen the edges and just make sure the last couple of feet of the pad is straight. I want to see first hand the handling characteristics that change.
  3. #18
    Everyone reports speed losses at Sacandaga of at least a couple mph because of the elevation, so you should pick up some at sea level.
    Virginia Beach
    This is an excellent point. While big pitch wheels are sexy and sound great in barside BS discussions ("man, I was turning a 32" at XXXX RPM, and I was smokin'!!"), if you have an engine that can turn and handle higher RPM (i.e. not rev limited, and not otherwise limited by intake, porting or exhaust restriction), a smaller pitch wheel is always better handling, easier to drive, and safer.
  5. Thanks JohnR thanked for this post
    Likes bigbluechevy454 liked this post
  6. #20
    longisland ny lindenhurst
    Quote Originally Posted by frederick55 View Post
    Sounds like it's running great, but I really like the yellow Action in the background!
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt
    20ft Allison grandsport
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  7. #21
    UTICA IL
    John Tiger that's how we rol,,l Real speed needs to learn what his name stands for and learn,,,gezzz
  8. #22
    Feb 2010
    li NY
    Why would I spin a STOCK INTERNAL 260 That high go ****ing jerk off
  9. #23
    UTICA IL
    That's what its made for,,, I could go faster then your speed with a 24 and out punch you by a ton throw that clever in the garbage just trying to help you out been there and done that...
  10. Likes bigbluechevy454 liked this post
  11. #24
    May 2009
    MASS
    Ditto!!
  12. #25
    UTICA IL
    Idiots and know it alls gotta love it...
  13. #26
    May 2009
    MASS
    Not me I'm fine running a 9 1/4 18 pitch
  14. #27
    Virginia Beach
    I'm not gonna sling dirt or call names. But how about numbers? If, for example, this 2.5EFI 260 will turn a 32" cleaver at 7500 rpm (BTW I am not in agreement about "throwing cleavers in the garbage"--it's likely the fastest and safest top end wheel he can choose for an overpowered light V-hull like the Viper). With 10% slip, he'd be in the 109+ range. But that 32" would be a hard wheel to handle, for anyone (even super star Viper pilots). The huge blades, steep pitch, equally steep blade skew all combine to create a paddle wheel effect when surfacing that makes any boat, but especially a light, flighty one, very susceptible to any inputs....wind, waves, driver input, etc.--and hard to react quickly. Now, I'm not saying twist that 260 at 9200 for miles turning a 24". But since the engine is still making healthy power at 7500+, why not turn a 28" at 8500 or so, obtaining the same or similar speed results but in a much more controllable and safer manner?
    JT
  15. Likes transomstand, pyro, bearclaw, texasvector liked this post
  16. #28
    Keep the clever. Best top end prop for the viper. If you can keep a 260 at 8g on a viper and do almost 106mph. I say prop and setup are looking real good. We don't go from point A-B and see who gets there the fastest. We run 3+mile straight aways and see who can hold it the longest at the fastest speeds.
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft redline
    18ft vking yt
    20ft laser 420
    18ft X-Stream Vking
    24ft banana
  17. #29
    Nov 2013
    Oak Hill Fl.
    Let me ask this? I am planning on using a 1.62 gear on my moded pad Vector. My thinking is with a light boat and the higher prop shaft RPM. I can spin a small pitch prop at higher prop shaft speed. This way I will not have to spin the crap out of the eng. Also the smaller pitch prop will not push the boat around in the ass..
    Seams a 28P at 7500 eng RPM would be more than enough to make ya squeal.
    Any thoughts?
  18. #30
    longisland
    wow another disscussion about whos the fasest. It's still me 1.87 gear at 8700 28 pitch chopper went like it was on rails
  19. Likes wing nut, DoktorC, texasvector liked this post
  1. The Worlds Fastest Hydrostream
    By Racemore in forum General Boating Discussion
    Last Post: 06-10-2021, 12:01 PM
  2. Worlds fastest outboard
    By Jo Boone in forum General Boating Discussion
    Last Post: 11-13-2009, 09:05 PM
  3. Worlds Fastest Outboard (OMC)
    By Maple Leaf in forum General Boating Discussion
    Last Post: 10-16-2009, 05:09 AM
  4. worlds fastest jet ski
    By beamrverbeek in forum The Scream And Fly Lounge
    Last Post: 06-04-2009, 09:31 PM
