Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: Dial Bore Guage
    Jul 2008
    Shreveport, LA
    Dial Bore Guage
    If I buy a dial bore Guage do I also need outside micrometers to zero it in?
    Thanks guys. Pete
    http://www.screamandfly.com/showthre...interior-re-do
    1986 Skeeter Starfire 150
    2000 Ranger R81VS
    1995 Liberator
    1988 Searay Sorrento
    1986 STV Pro Comp 280 "Area 51"
    1990 STV Pro Comp
    sw florida
    Ring gauge for bottom or top of range works good.
    Dago
    Mar 2004
    Durham Ct
    Yes....
    If your using it for cylinder bores, all you really care about is the actual skirt clearance. You measure the piston with a micrometer, then set the dial bore to the piston diameter. You them check the bore and read off skirt clearance.
    So YES you need micrometers.
    Michael D-1
    Dec 2011
    Sunny Oregon
    You don't need a micrometer. You just need a standard which you can use as a reference. The micrometer is handy as you can use it as a reference point but anything will work such as a ring installer or calibrated bore standard if you know the actual I.D.. It IS easier to use a micrometer but is it absolutely necessary? Not really.
    Jul 2008
    Shreveport, LA
    What I'm hoping to do is determine cylinder size on several motors. For instance, wether a particular hole may have already been bored oversize.
    I think it would be nice to be able to know if a hole is out of round or has taper before sending a block out for work. ( Also when buying a used block)
    2000 Ranger R81VS
    1995 Liberator
    1990 STV Pro Comp
    shreveport,la
    Yes Pete, buy a 3"-4" mic if you get a dial bore gauge. That one mic will serve you well on any outboard piston and to set your bore gauge
    Erik Kiser
    lindsay on. canada
    I say buy the Mic., but if you are not doing the machine work , only checking the size or for size of overbore use a vernier caliper .
    Aug 2004
    Venice, Florida
    Quote Originally Posted by frank jackson View Post
    Thats what I was thinking and then you just measuring the bore at the very top where it hasnt been worn and youll know what it was originally bored to.
    21' Paramount
    Mercury 300 Promax
    lindsay on. canada
    If he wants to check for out of round and taper he needs the bore gauge , he can set that gauge with the vernier . Its not as accurate as the mic but more than good enough to do checks with .
    Buy it......
    They move quite a bit after 15yrs of fishing abuse.
    Dec 2011
    Sunny Oregon
    Make sure you get one with a movable gauge face to be able to zero it. My dad bought one of those crappy Chinese ones thats always .040" off and non adjustable. I bought him a Starrett bore gauge for Christmas. Whole setup was $250. Might not be the top quality Starrett gauge of old but its a good rig.
  12. #12
    Aug 2004
    Venice, Florida
    He said he was just looking for bore size so thats why I agreed with the vernier.
    21' Paramount
    Mercury 300 Promax
  13. #13
    Buy the 3" to 4" micrometer you'll be glad you did. As far as Micrometers and gauges I'm a Starrett, Brown and Sharp or mitutoyo Fan. But Fowler makes some really nice precision tools that are 1/4 the price and very nice quality, accurate and reliable.
    The Fowler 52-646-300 2" to 6" in .0005 incriments dial bore gauge it's very nice and under $100.00 shipping included. They are all over Amazon and E-bay.
  14. #14
    Jul 2008
    Shreveport, LA
    Quote Originally Posted by HStream1 View Post
    Thanks everyone for all the input! I've got the Fowler mentioned above on order along with a 3" - 4" micrometer. Merry Christmas! Pete
    2000 Ranger R81VS
    1995 Liberator
    1990 STV Pro Comp
  15. #15
    I check mine with a 3"- 4" mic. Jay
    Jay @ JSRE
