Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 44
Thread: R/C Boat Plans
    Jan 2003
    Ottawa Ontario Canada
    R/C Boat Plans
    This is my (fast looking, but slow) New Bright Pier 57 Fountain Super Vee Light boat... It is so slow its not even funny. Listen to what I am planning on doing. Taking 2 (well 1 for right now since they are like $100 per) new Kyosho Dolphin Outboard II's and sticking them on the back... WHat ya'll think. THis possible. I am just wondering, how would I get these puppies to steer right. With these motors, would I have to change the controlls, or could I just connect the 4 (2 from each motor) to the main computer chip stuff as the old one? Any help or advice is appreciated...
    Jan 2003
    The Motor..
    Out Searching for my Dream Boat!
    Website
    Chevk out Tower Hobbies A really good website, and you can find almost anything in the world for RC. Good company.
    Kenny
    2000 Dodge Ram Sport V8 Magnum
    Savage 21 Nitro Powered R/C Truck
    Still no F#*@#%^ Boat!
    Germany by way of Florida
    Lightbulb Just a thought
    The boat you have is some what small & has subsurface (under the bottom of the boat) running gear.
    You'd need to remove the shaft log area & fill it in to get the bottom back to trueness.
    But getting back to the first statement about the two motors. I don't know if it would handle the weight of two motors & all the cells needed to run them. Plus the boat is quite skinny.
    One motor-- sure. But the speed will be in question. It could fly.
    Here's a link to some of the guys I talk to about r/c boats.
    Talk to the guys at RumRunner racing also... they really know their stuff (world record holders for fast electrics are members there).
    Give me some more info on your speed control size. If you run too many amps through it, she'll fry. Try the one motor for now, make sure it has plenty of cooling air, or water coil.
    http://www.rcuniverse.com/showthread...332&forumid=43
    http://www.rumrunnerracing.com/
    Good people at RumRunner.
    Hope this helps.
    Jamie
    Oh, look what I just bought also.
    13" long & fast as a buck !
    Jan 2003
    Re: Just a thought
    Hope this helps.
    Jamie
    That boat at the bottom is cool man. What kind is it? I have seen the GT 800 motors, as well as the 600's on a few sites. When I finally order my motor(s), it will be from Tower Hobbies. Now my next question, would you think it would be better to buy a blank hull and work my way from there? I'm new to this and don't know much about R/C controls and how it all works. Say I got a new hull like that with 1-2 motors, what is everything else I would need in order to make it run. Thanks...
    P.S How fast does that yellow one go?
    Boston
    thats my Offshore Mono with the twin 800 motors. I havent ran it yet I am waiting on a couple of custom parts. I estimate 30-40mph top speed. I will be running 20 cells to each motor.
    As for the topic of this post.
    It depends on how much money you want to spend. The angle of the prop is very steep. One dolphin would be good but then your going to need to gut everything else and put in a good radio and speen control. By the time your all said and done you could have bought a faster better boat. Now dont get me wrong spending money on this boat and building a rocket out of a dog sled could be fun and rewarding!
    Steven Vaccaro
    www.OffshoreElectrics.com
    Sep 2002
    PSL, Florida!
    if you really want to be happy get one of the $50 dollar kyosho radios and an $80 boat kit. it'll be close to what you would spend for both motors but alot easier and faster. plus you'll see how its all donr and get a feel for it. then you'll have better ideas if you still wanna mess with the boat you have now.
    Don't lick my boat, It makes it sticky!
    Another Hitman for the Sunshine Syndicate!!
    2011 Seafox Viper
    Boston
    If you want to put a smile on your face look into buying an AquaJet from us at www.OffshoreElectrics.com
    $189.99 for everything except batteries and screams right out of the box!
    This is about a 5meg video.
    http://www.offshoreelectrics.com/Videos/aquajetmod.mpg
    Jan 2003
    Thumbs up Thanks
    for all the advice guys... I have thought over the whole situation and have decided its going to be too much of a pain in the @$$ to rebuild the boat, which would, knowing me, break when I am working on it... I found the boat that has the same Dolphin Motor I wanted, with miminum assembly. Its the Kyosho Wave Master F-1 Tunnel Hull EP Kit. Its $99.99 US at Tower Hobbies.
    "This is a Semi-Scale F-1 Electric Tunnel Hull Kyosho Wavemaster Boat.
    FEATURES: Prejoined hull and deck constructed of ABS plastic
    Almost ready-to-run, requires only installing radio gear, assembly
    of the outboard motor, and applying the decals
    Comes with the Dolphin 550 outboard motor for scale appearance and
    performance (entire outboard moves to steer, not just rudder)
    Also includes forward-only micro switch speed control and decal sheet
    On-board radio and battery gear mounts down the hull centerline to
    improve overall stability and a water-resistant hatch protects the
    gear from water damage
    INCLUDES: Micro Switch Speed Control, 550 Outboard Motor with Cover, Decals,
    Servo Tray, All Necessary Hardware, Boat Stand, and Instructions.
    SPECS: Total length: 27.8" (705mm) Beam: 10.8" (275mm)
    Hull length: 23.6" (600mm) Height: 7.7" (195mm)
    Weight: 3.5 lbs (with radio)
    REQUIRES: 2-channel Radio with 2 Standard Servos and Receiver Battery Box
    6-cell Battery and Charger
    Building Equipment
    Although not required, any paint that is safe for plastic may be
    used to paint the boat & the outboard motor cover (like Formula-U)
    COMMENTS: Kyosho makes a water cooling coil for electric motors that will work
    well with this outboard motor (the water cool pickup is already
    molded into the outboard frame"
    In english, can anyone tell me what I'd have to do to get this running?
    By what I've read, I'd have to buy the radio(what else with it), install the outboard motor (does this mean I have to play with the steering of it too?).
    What are servos and receiver boxes. This kit looks pretty good to me, except for the fact I'd have difficulty puttting it all together.
    Jan 2003
    That looks pretty cool to me. That may be what I get now. I like the part where it says RTR, as I can't build stuff at all. Is this 189 US or CAD? I'd say US, but just asking...
  12. #12
    Boston
    US dollar. I can ship to Canada no problem, but I dont know what the taxes would be or anything like that?
  13. #13
    Jan 2003
    I checked out...
    the site and went through the steps. Paypal is the site I'd use, and its 189.99 plus $10.00 S&H etc... Makes it easy and thats all the costs I'd need. I'll check it out and let ya know. No discounts?
  14. #14
    Boston
    Sorry no more discounts. The shipping would be $20 in total. The shipping is for US stuff. I make no money on shipping. I would need a misc payment of $10 extra.
  15. #15
    Jan 2003
    I tried
    so 189.99 + 20.00?
    I'll see what I can do. What kind of speeds do I expect with the 770( or 700 whatever it is)?
