Results 1 to 15 of 18
    Mar 2013
    Colo
    Fuel line question...
    Im sure it been covered in here a lot but im new here and couldnt find my answer.
    What fuel line should I use for my Merc 2.5 and this junky fuel?
    Does any local auto parts store carry some or do I have to special order it?
    I would really like to replace my lines today but I dont have any marine stores close to me...
    Thanks Dustin
    NE Louisiana
    Same stuff they are running on cars. They are running the same crappy fuel. Gates is pretty good.
    Sep 2002
    Call Billy aka HOSER (Moreland Hose). He will get you set up with the right stuff.
    I need to call him next week to get new high-pressure fuel lines for my Merc.
    Mar 2013
    Colo
    You guys here dont buy into the EPA rated lines?
    How do I get in touch with Moreland Hose?
    Sep 2002
    Google, of course...
    http://www.morelandhose.com/
    Mar 2013
    Colo
    "Call Billy aka HOSER" Haha. When I read this I thought it was a guy building lines out of his garage not a big business. Thanks again
    Mar 2005
    North Mississippi
    Shields 368-0380 Type A1-15 fuel feed hose. 3/8" I.D. Low Permeation. Meets SAE J1527 Type A1-15 and ISO 7840 Type A1 standards. Complies with EPA and CARB very low permeation requirements. Meets USCG Type A1-15 requirements for pleasure boats, NMMA/CE type accepted, Fuel Feed for gasloine up to 85% ethanol blendend fuels, Diesel and Bio-diesel all blends.
    HP(frequent flyer)
    Ft. Lauderdale, Fl
    Quote Originally Posted by crankn101 View Post
    EPA rated is basically hose that meets the EPA's permeation standards..... anytime you see "EPA", it usually has to do with leakage or emissions and usually means the government is just taking more of your money. All new builds are required to meet EPA standards across the board and pretty much all new equipment has to be manufactured to their standards as well. So whether you like it or not, you will be buying into EPA rated stuff. What ever you use, make sure it's Coast Guard approved to prevent headaches in case of an accident or inspection.
    As far as what fuel lines to get, it depends on what you want to spend and what level of quality you want. You can go with any type A1 fuel hose all the way up to the expensive stuff with quality fittings. We use the Sheilds hose we get from the local supplier like Port Supply (West Marine) for most gas stuff and the Parker Blue hose and re-usable fittings for Diesel.....
    Mar 2013
    Colo
    Thanks for the info guys.
    Sep 2002
    Lakeland,Fla
    And just because it says EPA on doesnt mean its ethanol resistant. If it has that clear plastic liner in it it going to come apart.
    Fellow G-Man of the Sunshine Syndicate-Dixie Wrecked Chaptor..
    We Put The F. U. in FUN
    94 17MA Maverick 115 Yamaha
    2006 Mustang GT, with a belt driven air cleaner
    Jan 2003
    Georgetown,SC
    That's true,I had some of the line with clear liner in it and it did come apart.
    09 STV
    92 21 MTR Cougar,300 xs
    85 17 action
    90 26 regal
  12. #12
    Jul 2009
    Crawfordville fl
    Russell push lock hose works well from summit racing
  13. #13
    Mar 2013
    Colo
    Quote Originally Posted by VectorPat View Post
    This is exactly what im trying to avoid.
  14. #14
    Ft. Lauderdale, Fl
    Stay away from the Silverado hose..... crappy stuff
  15. #15
    Sep 2002
    Lakeland,Fla
    I just got thru fighting an issue on a customers boat that he had just replaced the fuel line on. He bought some cheap fuel line assembly, I think it might have been Attwood. He thought it was good hose as it said EPA compliant on it. The liner had come loose internally and was wadded up inside the hose, the hose was about a month old
