Page 5 of 20 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 LastLast
Results 61 to 75 of 287
  1. #61
    Jul 2004
    Connecticut
    I like the idea of holding off on the gas tank until last. Smart...............
  2. #62
    Jul 2004
    Orlando,FL
    hey my friend built a 23 nova last year with 2 ficht 225. ill see if he has any pics as he sold it soon after finishing. i believe it had 24" stock tank and a float type pod. i think frank had asked about it back when it was for sale.
    90 Vegas 89 200 78mph
  3. #63
    Jun 2010
    Rotorua New Zealand
    Quote Originally Posted by 200VEGAS View Post
    Hey Vegas,
    it would be great to know setback, engine mid length and a photo at both speed and rest. I managed to find four photo's of your friends boat when it was for sale recently. The guy that purchased it off your friend didn't keep it long. My conversion is coming along, just busy building a shed at home for it. Any information your friend could share with you would be most welcome.
    Thanks,
    SJ.
    Wellcraft Nova 230 XL, 300hp Johnson.
    Seahawk 45 Sport Fisher, twin 306hp Volvo.
    Steadcraft 28, Yanmar 300hp. Sold.
    Markline 800, Volvo 300hp. Sold.
    Haines Hunter V19, Volvo 170. Sold.
    16ft 6in Figlass Sidewinder, 140 Suzuki. Sold.
  4. #64
    Jun 2010
    Rotorua New Zealand
    My apologies for allowing this thread to go quiet. To get more work done on the boat I bought it home. Then we had such stink weather for our summer that work on the boat could not proceed and it sat under covers. So as I was going to build a shed for the boat anyway I got stuck in and put a roof over its head. The shed is nearing completion so its back to the project. Watch this space.
  5. #65
    Feb 2008
    Palm Coast, Florida
    Glad to see your still working on it!
    Drive it like you stole it!
    1991 Allison GSE 1998 225 ProMax
  6. #66
    Jun 2010
    Rotorua New Zealand
    Hey Hemi, I got to say it is great to be back on it.
    I have cut the longitudinal bearers to length, cut the bottom of the bearers and put on the base for the pod. Just about completed the "transom" on the rear of the pod. This will be three inches thick (4 laminates of 18mm Meranti ply) with 6 layers of 600grm Double Bias E
    glass at either end. As soon as it is finished I will post some more photo's.
    Final setback measurement is 20 inches.
    God it sure is good to be back on task.
  7. #67
    Feb 2008
    Palm Coast, Florida
    Keep up the good work! I'm anxious to see those pics!
  8. #68
    Jun 2010
    Rotorua New Zealand
    Well things have been progressing. Found some time last week and this weekend and have made some serious progress. Also I have taken some photo's. Given this is only the second time I have set up an outboard and previous time was nearly 40 years ago, I have been moving forward slowly and carefully, I hate having to do a job twice, do it once and do it right.
    Construction of the pod is complete less finishing and painting. When looking down on the cockpit you can see that there are two outer longitudinals which we had to cut when we rebuilt the transom. Still to be done is repair the cut longitudinals. This repair will include longer sections which will be extended out through slots which will be cut in the transom. These will be used to further support the boarding platform and will be constructed from 3/4 inch Maranti ply glassed over.
    Today I trial fitted the jack plate and the engine. I have not been able to source the correct grade of Stainless Steel bolts here in NZ so currently using 316 Stainless Steel. I will order the correct grade of bolts from the US this week. It was great to see the engine all fitted up, a great step forward.
    The plan is to now remove the jack plate with engine attached. I will over drill the holes in the "transom" on the pod and seal them with epoxy resin. I will then re-mount the engine/jackplate combination and rebolt. As soon as I am able we will take the boat to the lake and float it. I wish to check that the pod doesn't have too much bouyancy, confirm the boarding platform will have the correct amount of fall and I will use the opportunity to run up the engine. This will give me an indication on it's condition and how much work may or may not be required on it. I have a test prop so will be able to give is some revs while under load.
    So checkout the photo's, any questions or comments welcomed.
ID:	252402Click image for larger version.
ID:	252403Click image for larger version.
  9. #69
    Jun 2010
    Rotorua New Zealand
    More photos.Click image for larger version.
Name:	Pod with Jack Plate fitted.jpg
ID:	252405Click image for larger version.
Name:	Engine fitted 1.jpg
ID:	252406Click image for larger version.
Name:	Engine fitted 2.jpg
  10. #70
    Jun 2010
    Rotorua New Zealand
    And a couple more.Click image for larger version.
Name:	Engine fitted 4.jpg
ID:	252408Click image for larger version.
Name:	Engine fitted showing longitudinal bearers 1.jpg
ID:	252409Click image for larger version.
Name:	Engine fitted showing transom 1.jpg
  11. #71
    Feb 2008
    Palm Coast, Florida
    Looks GREAT!! I'll bet your anxious to put it in the water.
  12. #72
    Jun 2010
    Rotorua New Zealand
    Yeah mate, want to know how it floats so I can move on. Weather this weekend is crap so I suppose it will have to be next weekend. Not to worry still plenty to carry on with. I have removed the engine/jackplate and sanded the pod. In order to float the boat I will need to make sure everything is well sealed against the water, so it will get a good coat of epoxy resin. Now that the pod has been sanded, the next job was to install tubes in the bolt holes. This is done for two reasons. One is to make sure that there is no possibility of water entering the pod transom laminates via the Jack Plate bolt holes and also it will help stop any possibility of transom crush when the bolts are snugged up tight though in this layup that is highly unlikely. I had some Carbon tube on hand which matched the required dimensions.
    The plan is Saturday I will resin the pod and Sunday remount the engine/jackplate.
    Here's a couple of photo's.
Name:	Lining bolt holes in transom. 002.jpg
ID:	252667Click image for larger version.
Name:	Lining bolt holes in transom. 003.jpg
ID:	252668Click image for larger version.
Name:	Lining bolt holes in transom. 004.jpg
  13. #73
    Feb 2008
    Palm Coast, Florida
    From what I can see that's some pretty nice work. That pod is going to look factory when you get it done.
  14. #74
    Jul 2004
    Orlando,FL
    that looks nice and in my mind i feel the lift being transfered into the boat weird, huh. i havent talked to the guy that built that twin nova 23 in a while but i beleive they were 25 shafts and i would have to ask him about if he remembers the height. he had 19 viper props and i got him a set of 22 rakers and he really liked them. i dont remember specific's of rpm but i think he hit 65 with no setup. just put on the rakers. i really apreciate your work ethic looking at the job its nice work there... i'd be proud of myself....
  15. #75
    Jun 2010
    Rotorua New Zealand
    With the method I have used to support to pod and engine I will guarantee I will have no stress cracks. Also my method should work out lighter than more traditional transom strengthening methods.
    On your friends boat I had suspected the twins were 25in mids. That will be why he was running only 22in pitch props, I will be changing to one 25 inch mid but if I were to go to twins it would need to be 20 inch mids.
    Thankyou for your comments on the quality of my work.
