Results 1 to 13 of 13
    Jun 2008
    kingman az
    GPS antenna....where can i mount it???
    can i mount my antenna under the dash or somewhere else that its hidden? or dose it have to be on the topside of the deck of my boat...id prefer to have it hidden if possible....any ideas?...thanks
    shaun
    hidden gps
    I'm running all of my gps antenna under the deck. All seem to work fine.
    Apr 2007
    Quote Originally Posted by NICE PAIR View Post
    ditto
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
    Sep 2006
    Minnesota
    As long as the deck isn't conductive (carbon or metal) it shouldn't attenuate the signal any significant amount.
    hope it helps
    john
    To fish or not to fish? What a STUPID question.
    Jun 2008
    kingman az
    thanks guys...ill give it a try
    Nov 2007
    Asheville,NC.
    Under deck works fine on mine.
    Ft. Lauderdale, Fl
    A lot of the new GPS/Chartplotter systems are comming with under deck mounts now.....
    Des Allemands
    Gps
    On the Gambler that I used to have I had it on the floor way under the consold and with the Allison I have now it is under the dash with the gauges. Both worked as good as if the were in the wide open.
    Northern ILL.
    Just make sure the top of the antenna points up, have seen many of them be intermittent, beause there are mounted up side down or stuck on a side panel. 360 degree with out obstruction is ideal for satelite reception.
    UMPBA 926 Gas Jet
    upstate N.Y.
    mine's under the deck works fine[when the f*^%king battery doesn't go dead,about every 2 years!]
    why ask me ?
    Jun 2008
    kingman az
    Quote Originally Posted by stokernick View Post
    hey nick where exactly did you mount yours?....i was thinking about just sloopy-coning it to the underside of the dash will this work?...thanks
    shaun
  12. #12
    upstate N.Y.
    I used an ''L'' bracket[like a plant hanger]under the deck on the bulkhead in front of the foot throttle!
    why ask me ?
  13. #13
    ILL
    Quote Originally Posted by harrells View Post
    Me too!
    2018 Nordic 28 SS 450Rs
