Page 31 of 102 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 81 ... LastLast
Results 451 to 465 of 1526
  1. #451
    Suffern, NY
    Hey Mike
    I never answered your question about gear case height. I have an electric jack and have always jacked it back down as I slow down so as not to lose pressure. I think that when I'm running full out its probably bottom of propshaft about 1" above the pad. Without low water pickups you will probably run as high as you can go and still maintain 12 psi anything below thats not safe. If the top of your propshaft at that psi is more than an inch below the pad you will be able to go faster with a low water PU on your case. A longer case crates more drag but when Its up and out the drag goes away thats why your trying a surfacing type prop. How are you set up, do you have a jack or what?
  2. #452
    Suffern, NY
    I went back to page 23 of this thread and answered my question. You should be able to dial in pretty easy but if you ultimately go with a low water PU case you will need to go with a electric jack to get the most out of it. You can actually jack higher at top speeds than at lower speeds so you will get a little more height with the electric.
  3. #453
    Jan 2007
    lindenhurst
    Thank you for the information. If I remember correctly my propshaft is about 1 1/2 inches below the pad, and I still have plenty of water pressure. In the springtime I will raise the motor 1 hole and adjust the jackpate so that I have room to go up
  4. #454
    Suffern, NY
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"><meta name="ProgId" content="Word.Document"><meta name="Generator" content="Microsoft Word 11"><meta name="Originator" content="Microsoft Word 11"><link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CCOMPAQ%7E1%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--><!--[if gte mso 9]><xml> <o:shapedefaults v:ext="edit" spidmax="1026"/> </xml><![endif]--><!--[if gte mso 9]><xml> <o:shapelayout v:ext="edit"> <o:idmap v:ext="edit" data="1"/> </o:shapelayout></xml><![endif]--> Hey Mike got your PM. I guess it will be a while before you get to see the results of the chopper. Are you gona go to the Rondack Romp this year. If so maybe I’ll see ya there.
  5. #455
    Jan 2007
    lindenhurst
    I plan on doing the romp!!!! My friend and I want to take the boats up there, maybe I will have this thing dialed in near 80 so I can try to keep up with you guys
  6. #456
    Jun 2005
    near Lake George, NY
    I guess I'll have to bring the Velocity if all you V22 guys are coming
    1983 Shadow 21, Yamaha 250 HPDI
    1961 Grumman 13, Johnson 15, "Gunkhole"
    1931 Hacker Hydro, Phantom 75
    1930 Sea Lyon 28, Scripps 208, "Tomahawk"
    1929 Chris Craft 24, Chrysler 115, "Reflection"
    _________________________
    Photography:
    KAOS Imagery
    Flickr
    Facebook
  7. #457
    Hey
    Quote Originally Posted by cutwater View Post
    Not all Velocitys are goin
  8. #458
    Jun 2005
    Well, I'm gonna bring the Shadow too
    Photography:
    KAOS Imagery
    Flickr
    Facebook
  9. #459
    Suffern, NY
    Sounds good. I'm gona try to get Chris M to come again with his twin engine Shadow.
  10. #460
    Jan 2007
    lindenhurst
    We should wake up Highvelocity and get him to make the trip also , Venomous I want to take a shot at that challenger of yours and see if I can keep up!!!!
  11. #461
    Hey
    Quote Originally Posted by mikeylarge View Post
  12. #462
    Nov 2005
    Egg Harbor Twp. NJ
    Where is the Rondack Romp?
    David
    2000 Powerplay Sportdeck
  13. #463
    South Jersey Shore
    If I'm waking up for the Romp I hope it's in a warmer place than here. My boat would be ready to go too Mikey.
    I have everything out of it, and I mean everything!!! She just needs one seat and battery...haha.
    Dave, I could even make a speical cover to snap on the rear to make her into a one seater. It would look like a big kayak...lol
    Mike, you gatta prop with some pitch for me??? With no weight I will be runing out of prop...lol
    Boats love hundred dollar bills.
  14. #464
    Quote Originally Posted by HighVelocity View Post
    If were ever in the same place together bring the wrenches and try this 28 trophy DAH did for my setup. Im still messing with lowers but Im going to a torquemaster as soon as I can get the stuff swapped this winter sometime.
  15. #465
    Jun 2005
    Quote Originally Posted by Powerplay25 View Post
    The Rondack Romp this last year was the "Go Romp Yourself" non event...the original organizer retired from putting it together...
    But it is typically middle June on Great Sacandaga Lake which is 45+ minutes from Albany, NY. Specifically, it's based out of Northville. Sacandaga is about 27 miles long...
    Photography:
    KAOS Imagery
    Flickr
    Facebook
