Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 67
  1. #46
    Apr 2008
    Washington N.C.
    Never had a 2.4bridgeport but I've had a few 2.5 bridgeports and they run very well!
  2. #47
    Thought all 2.5's were oval port, what years and models were bridged ? Had early 2.5 Carb it was oval. Dave
  3. #48
    Sep 2002
    There were a few "Z-port" 2.5's that has a diagonal bridge in the exhaust port.
  4. #49
    Oct 2018
    Santa An, CA
    What prop were you running on your STV with the BP?
  5. #50
    what pushes the fastest out board boat in the country?
    a bridgeport omc racing engine as all OMC custom block racing engines are
  6. #51
    Bridged ex ports ...
    Just one more thing ya have to do …
  7. Likes powerabout liked this post
  8. #52
    Tough to do one Nic coated one witbout removing the plating.
  9. #53
    Oct 2010
    Harrisburg,Pa
    Worlds fastest outboard is a OMC 10,000 RPM
    The worlds FASTEST OUTBOARD MOTOR is an EVINRUDE V8. Running at close to 10000rpm with a overdrive gearcase this incredible motor powered a 20' 3 point hydroplane to a 2 way average of 176.556mph. During testing it easily exceeded 190mph but was damaged after hitting an object in the water.Dec 26, 2010
  10. #54
    Quote Originally Posted by Dave Strong View Post
    Uncle Dave .. from Uncle BBQ's side of the family ..
    There were many 2-cycles built using a "bridged exhaust port" . I quoted the Hodaka manual . The fast OMC's I've seen had this modification done as well as the little oil hole ..
    The OMC's .. yea ~ no they weren't done with a small wetstone .. They were done with a big ...
    The Merc Bridgeports .. are there any left .. ?
    The brief history that I know about them is , that they were 3 3/8ths" bore.
    They came from the factory with :
    5 cylinders that were plated with industrial chrome.
    1 cylinder that had a random steel sleeve ... sometimes more ..
    Now ifin the block didn't have the little clearance deal done "before" it was plated, chances are pretty good that it became a member of the "soon to be extinct" club ..
  11. #55
    I still have a 2.4 Bridgeport, original plating and no cracked bridges. Pistons have a relief machined in them, the original Mahle pistons were like that, as the Merc replacement Wiseco's. Steel bore motor your suggestion would be a smart move.
  12. #56
    worlds fastest outboard had steel sleeves....just saying
  13. #57
    And it came factory like that.⁰
  14. Likes powerabout liked this post
  15. #58
    Uncle Dave ...
    Just in case ya haven't heard , OMC built the ..
    I have no doubt you have a pristine 2.4L in your collection ..
    I just never seen one ..
    Power .. Your boy Bobby Worthead has done more to **** block water based record attempts than any left~wing group of people could ever hope for ..
    You happen to know what size jets they had in "the hammer" .. ?
    Long , high internal capacity , single end fed , spray bar systems have poor distribution characteristics .
    Why wasn't the boat ever run again .. who has the motor ?
    I got a canole' that says they hurt it .. kept it quiet .. locked the books , and quit
  16. #59
    Western Pennsylvania
    So why did merc stop making BP engines?
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  17. #60
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Euroski View Post
    Behind the liner porting on the 2.5 was better, no more finicky bridge, more power, less stuck pistons...
