Results 1 to 7 of 7
    south florida
    fast bottom paint?
    im fixin to buy a little boat and paint the whole thing, im wonderin what i can do to the bottom to help with speed that wont brake me, and if the paint is expensive could i just paint the pad????? what would you do?
    they last longer if you run 'em hard
    Mar 2005
    Lakeport, MI
    dry graphite lubricant
    http://www.slipplate.com/
    dry sand with fine emery then fine steel wool after application.
    Ontario, Canada
    if it's a glass boat, then you're best bet is to clean up the bottoms (especially the running surfaces/pad) so that it's perfectly straight, true and clean; then sand with 400-600 grit paper.
    Norway
    HI!
    If you need bottom paint, check out International V17M two component epoxy based paint. Its very thin and you can water sand it afterwards. I use it on my Phantom 25, and I kept the top speed compared to a water sanded bottom without paint. The main reason is that this two component paint is very thin and hard.
    Cheeers, ToffenG
    Mar 2005
    Lakeport, MI
    Mar 2005
    Lakeport, MI
    picture of wetted surface painted with Slip Plate for improved speed and fuel savings
    Nov 2002
    peterborough
    I know a guy who used speed bottom coating, it took off before the boat did . And he never did catch it thanks.
    free spirit / ONTARIO, CANADA.
