Results 1 to 15 of 27
    Jul 2001
    Springfield, MO
    What epoxy to easily blend in nose cose ??
    I'm redoing the nose cone on my lower unit. The previous owner only epoxy'd it on....and I just really didn't trust it...it was starting to crack. I broke the nose cone off (came off pretty easy), and had a shop weld it back on.
    I'm assuming that I need to use epoxy instead of a body filler to blend the cone back into the LU. What is a good epoxy to use that will stand up over time, but will also be easy to sand and shape? I've tried using stuff like JB Weld in the past, and that stuff is almost impossible to sand.
    I would like to get it locally if possible...I don't want to have to order something and then wait a week to get it. I want to start working on it this weekend.
    Thanks
    Ian
    ...boatless for now.
    Illinois
    West systems epoxy with filler like 404 is a good bet. I personally would use body filler. If the you give a rough surface to bite it works very well. Feather edge the cone so there is no edge where the filler meets the cone piece.
    Mar 2005
    Mid-Michigan
    Use PC-7. You can get it at most hardware stores etc.. It is very durable and sands O.K.. If you want it to be durable it won't be easy to sand, those 2 things are mutually exclusive.
    Mar 2007
    Ontario, New York
    I used West System G-Flex for most of the filling when i put mine on, then went to Formula 27 for the fine detail... G-Flex is pretty hard and tough to sand, Formula 27 is soft and easy to work with but is easy to chip if you hit even small sticks and giant clumps of weeds.
    Dan Cario
    1994 STV Mod-VP w/225HO Ficht Evinrude
    1987 22' Velocity w/225HO Evinrude E-Tec
    Jul 2001
    Springfield, MO
    Quote Originally Posted by Brad Zastrow View Post
    I have used body filler in the past, and even if I rough up the case with 60 grit paper, it still ends up getting pulled off after a few 80mph runs. Last summer I was repairing missing chunks of filler in my LU after every trip to the lake. I finally got sick of it, and decided to do it right.
    Ian
    Jul 2001
    Springfield, MO
    Quote Originally Posted by drasticplastic View Post
    Thanks...I will give that a shot. What brand is that??
    Ian
    Orange City, FL
    Quote Originally Posted by imq707s View Post
    I'll second the PC-7. I think the brand is PC. ACE hardware usually has it. Not sure about the other big box stores.
    Jul 2002
    Lafitte, La
    Quote Originally Posted by Slider View Post
    i'll third pc-7
    Craig Creppel
    DR-20 TRIAD
    ALLISON XB 2002
    Lannon WI
    I love to use this stuff
    The green system
    http://www.jgreer.com/
    2006 Action Marine Comp
    1980 Ventrua 2
    shreveport,la
    The "PC" site say's that it's available @ Home Depot... My Brother will soon be re-filling His case, and I'll tell Him about this stuff...
    Kevin Kiser
    Jul 2005
    snohomish washington
    i used fiberstrand from napa and not a problem one. now the paint on the other hand is going to crap
    88 cougar mtr 19'
    '93 2.5 fishin motor made into a 245hp
    '71 marlin 16' flat btm v-drive 550hp 427ci set up for drag.
    Originally Posted by Hydrophobic guy
    I'm not a contractor but, I did stay at a Holiday Inn Express last night.
  12. #12
    Jul 2001
    Springfield, MO
    Yes, Home Depot should have it. I'm heading there right now to pick some PC-7 up.
    After I get the epoxy all smoothed out...what about paint? What grit should I finish the epoxy with? Then should I go over that with an epoxy primer then paint.....or just go with paint straight over the epoxy? Base coat then clear on top....or just single stage paint??
    I've repainted this LU so many times...I want this to be the last time for a while.
    Ian
  13. #13
    Jan 2007
    In meinem geheimen unterirdischen Versteck, USSA
    MAS 2 part epoxy with micro beads 14,000 psi tensile strength use a fast reducer. I've hit rocks with the stuff with almost no damage.
    For paint I use the ceramic hi temp engine paint. Not a single chip or blister and I beat the livin crap outa the boat just about every weekend.
    .......................................................................LETS STORM THE CASTLE BOYS!
  14. #14
    Jul 2001
    Springfield, MO
    Well I went out and bought some of the PC-7 this weekend and blended the cone on my case. Man, that stuff is great!! It has the consistancy of body filler, but just a little "firmer". Spreads on great......haven't tried sanding it yet, hopefully it sands easy.
    Thanks for the info guys!
    Ian
  15. #15
    Dec 2003
    rockford ill.
    home depot may not
    Ace will.
