Results 1 to 10 of 10
Thread: Boyesen Reeds
12-17-2008, 06:55 PM #1
Boyesen Reeds
I just bought a set of seven pedal red cages that had some "lightly" used reeds on them. Seller said they were fine but I dont know the tolerances for these reeds. Using a feeler guage, .007 of space between top and bottom plates at ends. Is this normal or are these done?
Thanks
86 Daytona 19'
86 2.4 MOD-VP
http://www.youtube.com/watch?v=6P8J-lj607I Me and My Bro Tearing up the Local Lake! Nordic and Eliminator with matching Jelcoat.
12-17-2008, 07:20 PM #2
Supporting Vendor
- 11,838
- 163
- 11
- 797
Others may disagree , BUT I've found if you can see light between the reed and the cage ( same as a leaking intake valve on a car ) you will give up some bottom end snap...The argument is that when the piston drives down for bottom crank case compression the reed will seal , I've found that "theroy" with my own engines to be
.. You line up equal boats, props, motors, and drivers and one has leaking reeds and the other is sealing 100% the sealing motor will hand you your arse...
Been there, tested it and the stop watch will make up your mind for you !
Also I have had better luck with the Tony Doukas Reeds as far as sealing and longevity over any reed I've ran ...
My .02Jay @ JSRE
12-18-2008, 05:33 AM #3
I have found the metal plate that holds the boyesen reeds in to be a soft metal, and as they as in the instructions not to over tighten the screws as it my lift the reeds from the block, But it will bend the metal plate as well which lifts the reeds from the block, it appears that the OEM backing plates are thicker metal, it may be a good idea to make a thicker plate
Dave W
warbymotorsport.com
12-18-2008, 08:55 AM #4
Screaming And Flying!
- Springfield,La.
- 6,579
- 17
- 2 Thread(s)
Try loose'in up tha reed straps, and then retightn'in them...sumtimes it will close up the gap.......If not, I agree wit shorty, replace them...and the TDR's are a better reed in my non-professional opinion
12-18-2008, 06:35 PM #5
Sounds good guys, I will take a look at the metal plates and screws. Probably a good idea to replace them. Thanks again for you input on these.
Thanks
Pat
86 Daytona 19'
86 2.4 MOD-VP
12-19-2008, 01:36 PM #6
Jay do they make TDR for OMC V6's... was on there website and didnt see them.
Dan Cario
1994 STV Mod-VP w/225HO Ficht Evinrude
1987 22' Velocity w/225HO Evinrude E-Tec
12-19-2008, 05:20 PM #7
Supporting Vendor
- 11,838
- 163
- 11
- 797
Sure they do... Call for prices and shipping info..
JayJay @ JSRE
12-19-2008, 10:15 PM #8
good deal thanks
Dan Cario
12-28-2008, 12:56 PM #9
Yep, I've got a set in my fishin motor and they work twice as good as the BOYESENS did. I got 4 hours out of my BOYESENS before they quit sealing good and spitting at idle. Switched to the TDR's and couldn't be happier. Noticed a MAJOR improvement in the off idle performance as well.
1989 20' HYDRA SPORTS 2000CC, 225HP EVINRUDE 88 powerhead 98 mid, TDR reeds
and a basic clean up porting on it
Runs 49 MPH not bad for a heavy deep vee
12-29-2008, 01:37 PM #10
Hi Jay,
I sent you a PM regarding the TDR reeds
Thanks
DaveDave W
warbymotorsport.com
