Results 1 to 15 of 21
    @ the gas pump
    will it fit??????
    will a 16" diameter prop fit on an outboard?? if not what is the biggest? thanks
    Grafton, WI
    Depends
    I just measured my 2.5 litre torquemaster and it's 8.125 from the center of the propshaft to the bottom of the antiventilation plate. I don't know about all the other gear cases though.
    Any fool can make something complicated - it takes a genius to make it simple.
    @ the gas pump
    thanks my sporty is the same....I just dident know if there is a min on clearance you need from the tip of the prop to the cav plate.
    has anyonne ran a big prop like that on a full tunnel?
    Aug 2003
    Lakes Region NH
    NO and why would you??? to hard to turn
    Quote Originally Posted by 1BadAction View Post
    I'd slam my d*** in a car door before I'd comment on this thread.
    This almost beats cheesey!!!
    @ the gas pump
    let me give you alittle more info on my setup. 21' cat with a drag motor witch is not the best motor for a big tunnel. the prop it has liked the most to date has been a 15/24 pitch cleaver. it has great topend but slow in the midmange and with the rpm range the drag has I was thinking of a 16/22 the big blade to carry the boat and a small pitch to spin eazy and run the motor higher aswell @ high speeds. any 1 ever try that??
    May 2005
    Greenville, NC
    I tried a 15 1/2" prop once. Only once, didn't work too well.
    Ló fasz racing
    Joe Horvath
    @ the gas pump
    Quote Originally Posted by jphii View Post
    what kind of boat did you try it on and what dident you like?? thanks
    May 2005
    Greenville, NC
    An OMC on my old Seebold. Even with the grunt of an OMC it had a hard time getting out of the hole. The only thing it did to well was top end, but it took a while to get there. I actually tried it once on my Mirage too, but it was pretty much the same. And the Mirage comes in under 1350 with me in it running.
    Ló fasz racing
    Joe Horvath
    Nov 2004
    LEBANON OREGON
    outboards dont like that much diameter generally.. a 16 will fit but only in big houseboat applications are they used on outboards... and in like 11-13 pitch... for a 21 footer look to a 14.5X 24 or 26..
    Aug 2003
    Lakes Region NH
    If it was me I would think about regearing it
    what do you have 1:87???
    @ the gas pump
    Quote Originally Posted by 150aintenuff View Post
    thanks for the replys. the boat didnot like the smaller sizes. I tryed a 14.5/24 chopper, a 14.25/26 4blade cleaver and they didnot work aswell as the 15/24 cleaver in carrying the boat and not even close on topend.
    and yes it has a 1.87. what are you thinking 2/1 ???
  12. #12
    Aug 2003
    Lakes Region NH
    2:1 will allow you to get more torque to the prop making it pull harder on the bottom and mid and like you said let it spin to get good top mph#'s... I think you would fingd that the boat would bew better in the common areas with only small loses in the top........
    also you may try cutting down to a 14.5 X 24 this will allow more slip until the motor can spool up to the power ......
    More info on
    make of boat
    setback
    weight
    then we can really help ya out
  13. #13
    Sep 2002
    It's a Jones Tunnel.
    Deep, heavy, roundy-nosed true cat with a big fixed tunnel tab.
    Here it is, parked next to my boat.
  14. #14
    Mar 2004
    Newaygo, Mi.
    Lots of blade area (oughta carry the boat real well) and a little less pitch.........sounds like a winning combo to me. You already tried about everything you could get your hands on with 14 1/2" or less in diameter and 26p on down with the best prop still being your 15" diameter cleaver........hands down. Big Daddy thinks ya should try that big rascal.
  15. #15
    Sep 2002
    Have you guys ran it with anything else, other than the big cleaver and a round-ear? You need to really start a new thread called "21' Jones Tunnel cat setup" and see if you can draw out some experience from the few who have run one, or anything remotely similar. I have seen how the boat rides with four aboard, but I'm not sure I understand what you're looking to gain. More stern lift? More response to trim? a bit of both?
    Have you ever run an ET or ET cut on it?
