Results 1 to 5 of 5
Thread: F block Reeds
05-05-2024, 04:17 AM #1
05-06-2024, 12:23 PM #2Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,277
- 216
- 30
- 590
Those are obviously not 7 petal,not sure what they are,I have several different 4 petals similar to yours,I would need a sample,Chris
05-06-2024, 03:09 PM #3
These came out of a s3000 I think.
When I said 7 petal I meant 7 petal front half.
I'll post some measurements.
I run them in a 7000rpm 240hp carb motor on a 19ft mono.
Circuit racing.
One interesting aspect of these cages is that the clamping screws are set lower down on the cage than on the stock 7 petal type.
That allows them to be stuffed 1/8 inch into the case without the screws hitting the case.
They may be billet cages I don't know.
Edit.
3mm staffers only work with 8118 rods, not 5250.
05-07-2024, 03:02 AM #4
05-07-2024, 09:51 AM #5Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,277
- 216
- 30
- 590
Cool,new one on me...if you can get them youre set,if not I can cut some,let me know...what are the prices?
NZ Sidewinder liked this post
is the rubber 4 petal reeds and block better then 5 petal boyseen reeds?
By camaro7081 in forum Technical DiscussionReplies: 18Last Post: 04-05-2022, 05:35 AM
