Results 1 to 10 of 10
Thread: Chris Carson Reed Chatter
05-04-2024, 12:26 PM #1Junior Member
- Jul 2022
- OH
Hello,
I just finished assembling the reed assemblies on my 210 Sportjet motor. I put Chris Carson Reeds and stuffers in. I used the existing cages (rubber was good and flat, no cracks). When i tightened up the reed assemblies (using the stock reed stoppers, i noticed a very small amount of gap between the tip of the reeds and the cage. I did not over-torque them. I used locktite blue and snugged them down.
When i spin the motor over by hand, I noticed a small amount of chatter. I assume that this will go away once i use the starter/its running.
Thoughts?
Thanks, Jason
05-04-2024, 09:00 PM #25000 RPM
- Oct 2008
- Plainville, CT
- 808
- 420
- 25
- 380
- 67
I've done several reed replacements and never remember space after tightening them down.
05-05-2024, 09:37 AM #3Team Member
- Lake Coochiching, Ontario
- 7,841
- 27
- 285
- 507
- 1645
- 6 Post(s)
My reeds have never said a word
05-05-2024, 12:04 PM #4
The rubber swells a bit over the years most likely from ethanol laced fuels or other additives is my guess. When i swapped TDR reeds into mine I could also see daylight between the reed and the block. I blocked them down and now they are light tight so to speak. See this thread for pics
https://www.screamandfly.com/showthr...istakes!/page6Hydrostream dreamin
05-06-2024, 08:58 AM #5
Sounds like you need to sand the Reed blocks flat. Boyeson says to lay a piece of sandpaper on a flat piece of glass. Rub gently until flat. Start with 220. Finish with 400.
LakeFever liked this post
05-06-2024, 12:20 PM #6Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,279
- 216
- 30
- 590
Standing open a few thousandths is not a problem,as long as they will close with a gentle touch of your finger.Realize that the reeds open and close about 15 times a second at idle,and only go faster from there,they will land on the cage and quickly crankcase pressure keeps them closed,Chris
05-06-2024, 03:10 PM #7
05-06-2024, 07:08 PM #8
When I get a set of reeds from Chris, they come in a nice plastic case. When I open the case I notice they have two small rubber bands holding them together. My first clue that they are all flat is when I cut the bands off, they continue to lay in a flat stack ... just like when they had the rubber bands on them.
I usually assemble reed cages on a piece of flat marble that sits next to my safety clean machine. As single leaf's, they also lay flat.
Now if I assembled a reed block and the reeds had any air gap .. would I think :
A) there was a problem with the reed
B) I had a warped azz block
Chaz = thinkin, Carson offer's the best tech support in the industry ..
05-09-2024, 07:39 PM #9Junior Member
- Jul 2022
- OH
Thank you for all the help. I took some time and decided to take these apart and really take a look at what was going on.
First I looked at all the surfaces, and played with the reeds on the cage by gently squeezing where the stop plat attaches. I found that there was a small amount of rock on most of them. I decided to get back to the sandpaper and flatten this out. I started with 400 soaked in oil and finished with 600 grit. I watched a couple of videos of people doing it and followed with the small circles figure 8 patterns. Once I did this, I could immediately see a difference. I then assembled all the reeds with blue locktite and tightened the screws down. I have to admit, it was a little lighter than the original torque i did.
I found that if I did the outer screws first and went all the way till the lockwasher was flat, then did the same for the inner two.... Afterwards I did a final snug of all. I would say it was about 1/8 of a turn more. They still felt looser than I would like but from everything I see, they don't need to be that super tight.
Am I wrong here?
05-09-2024, 07:43 PM #10Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,279
- 216
- 30
- 590
You’re good, Chris
7 petal reed cages with Chris Carson Race reeds
By moomba in forum Misc. Parts and AccessoriesReplies: 3Last Post: 10-30-2015, 10:02 PM -
OMC Tech: Another Reed Question for Chris Carson
By groundloop in forum Technical DiscussionReplies: 6Last Post: 05-21-2011, 11:46 PM
