Results 1 to 15 of 17
    Dec 2003
    Indianapolis,Indiana
    Valero trailer setup
    I am putting my 1984 Valero on a Roadrunner tandom axle trailer that held a 19' tunnel boat.The boat is on a Hustler trailer now that was the original one. Can the bunks on the tandom axle be flat and I just make sure the are the same distance apart and length as the Hustler? The Hustler trailer bunks are adjustable as far as angle but I just dont see any angle to them.Any body with any experience give me some advise?
    Nov 2004
    LEBANON OREGON
    set the bunks flush to the inside of the second strake from the pad( center of the V protion) that way you not only are supporting the hull properly 1/4-1/2-14 but it gives you the self centering ability when cumming on to the trailer.. PERSONALLY I would use tandem bunks so weight was caried over more area myself... My EZloader trailer under my valero is getting a second set of bunks and center rollers so it is supported over the pad, and the outermost strake( right under the float boxes)( and inner most strake)(STRINGERS) and I should be able to load it in ANY wind or current
    Dec 2001
    Sunbury, Pa
    no you cant do it. You have to fix the sleekcraft and put it back on the tunnel trailer. How are you making out with that?
    Ralph Musser
    27' Fountain Fever W/ 525SC
    22' Rapid Craft W/ Evinrude 300 V8 January 2009 BOAT OF THE MONTH SOLD
    24' Triton 240 Gold W/ Mercury 60
    14' Royalcraft W/ Evinrude 75 father/daughter project
    Nov 2004
    LEBANON OREGON
    yes he can.. valero is faster anyhow.... or atleast capible of faster...
    Dec 2001
    Sunbury, Pa
    Quote Originally Posted by npartin
    Not necessarily. Sleekcrafts have run triple digits. He knows I am kidding about the boat fitting the trailer.
    Ralph Musser
    Nov 2004
    LEBANON OREGON
    so did I... jus tryin to make him feel better..
    Dec 2003
    Talking Sleekcraft...
    After digging into the Sleek found out transom was torn from bottom.Cap was shifted.Many holes...Insurance paid well and gave me the remnants of the Sleek. I watched as landfill employees flipped a coin to see who ran over it with the dozer. Put the new components left from the Sleek all on this Valero.Its a hoot!
    Dec 2001
    Sunbury, Pa
    what did you do with the cover?
    Ralph Musser
    Dec 2003
    its around here somwhere.want it?
    Voorheesville, Upstate NEW YWAK!
    I have 4 bunks on mine. 2 up in the deepest part of the tunnel and 2 angled just out side the pad. I also have 3 rollers up the middle although only really use 1 up front on the keel. The other 2 are just a piece of mind when loading.
    Tom
    Dec 2001
    Sunbury, Pa
    Quote Originally Posted by waterrocket
    I may be interested. Do you have any pictures of it? Email me the details. Thanks.
    Ralph Musser
  12. #12
    That's how I set my trailers up. Two 2x6 outer bunks and two 2x4 inner bunks. Bunk supports are lined up with the edge of the transom and bottom. After all, I did set it up for long term trailer storage.
  13. #13
    Oct 2003
    Waterford, Ct
    Gregs Lower Unit
    That thing is polished like a mirror.
    Any speed gain by doing that??
    Art
    18S Skater,05 280 Offshore
    10' Bombard,04 15 HP Johnson
  14. #14
    Dec 2001
    Sunbury, Pa
    Quote Originally Posted by platypus
    Art
    I think that is just a mock up of a motor. The lower unit is chrome plated plastic and I think it is empty under the cowl. It makes the boat alot lighter to push it in and out of the garage for pictures.
    Ralph Musser
  15. #15
    Nov 2004
    LEBANON OREGON
    COPY GREGS TRAILER EXACTALLY that is how mine is and I also have rollers supporting the pad and gives a centerline to hit at the ramp..
    My fissin boat is also that way and I can load perfectly straight without guidons in 50 mph crosswinds and 2' chop on the trailer.. set shallow and power on at WOT.. doesnt matter the conditions.. and it works well for long term storage as well.. my fissin boat sits for 3 months over the winter due to it bein snow bound and have had ZERO problems.. I also used TREX decking with a 1/4" steel plate under it for support so never have a rot or maring issue on the aluminum of our fissin boat, the hydrostream will have carpet cause its softer..
