Results 1 to 12 of 12
Thread: Plugs for 300x
10-17-2017, 07:10 AM #1Member
- Mar 2017
- central fl
- 95
Plugs for 300x
I saw on a previous thread where some are using the NGK BR8IX and NGK BR8HS for 3L motors. Is this a sub. for the 300x motors? I am using the Champion QL77PP now with a rough idle and low end. Any idea if the NGK would help?
Thanks..
10-17-2017, 07:23 AM #2Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,637
- 606
- 919
- 1698
- 7130
- 3 Post(s)
I have never been a fan of Champion plugs but the X motors have been quirky when I have run anything else in them.
10-17-2017, 08:21 AM #3Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Seems like you have to check the gap on any plug you buy now. Had a 300xs i worked on that was running bad and discovered the gaps were all over the place. Owner had not checked them before installing himself. I set gaps properly, and it ran fine. jm2cts
10-17-2017, 08:30 AM #4
Sorry, double post
Go Time
26 Regulator twin 250 EFI
10-17-2017, 08:31 AM #5
The QL77PP have always run the best for us in the X motors. And we run them hard.
Go Time
10-17-2017, 10:09 AM #65000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
10-17-2017, 10:25 AM #7Member
- Jan 2007
- Florida
- 81
- 7
- 45
10-17-2017, 10:47 AM #8
There was a service bulletin on them concerning plug gap. I dont have it in front of me, but I seem to remember it was increased to .040... someone will chime in if thats wrong.
Go Time
10-17-2017, 11:57 AM #9
2001-03 APRIL 2001
Printed in U.S.A. -
2001, Mercury Marine
Page 1 of 1
No. 2001-03
WARRANTY INFORMATION
SERVICE INFORMATION
Correct Spark Plug Gap for 300X Pro Max
Models
All 2001 Model Year 300X Pro Max Engines
Situation
The spark plug gap specification is incorrect on the emissions sticker attached to the engine
and in the Operation, Maintenance and Warranty Manual. The incorrect gap is 0.035 in.
(0.89 mm), which is too wide.
Correction
The correct spark plug gap for the 300 X Pro Max is 0.025 in. (0.64 mm). When checking
or installing spark plugs, set the gap at 0.025 in. (0.64 mm)
PlumCrazy liked this post
10-17-2017, 12:43 PM #10Member
- Mar 2017
- central fl
- 95
Thanks, that is some good info..
12-24-2017, 09:58 AM #115000 RPM
- Nov 2009
- hardyville va
- 367
- 7
- 38
- 43
12-28-2017, 07:21 AM #12
Br8hs work fine, I wouldn't put champions in a lawn mower! If u run it hard for long periods run the br9hs, I usually gap them to .028-.030. u can use the br8hix, more expensive and an iridium plug.
300x spark plugs
By Michael J Giesler in forum Technical DiscussionReplies: 4Last Post: 06-30-2014, 07:27 AM -
300X Plugs
By Scott Tharpe in forum Technical DiscussionReplies: 1Last Post: 08-19-2011, 11:43 AM -
300X fouling plugs
By swampster9 in forum Technical DiscussionReplies: 3Last Post: 02-14-2008, 05:21 PM -
Spk Plugs In A 300x
By jerry in forum Technical DiscussionReplies: 4Last Post: 08-01-2006, 04:03 PM -
Plugs For A 300x
By beer30 in forum Technical DiscussionReplies: 0Last Post: 08-05-2004, 08:21 AM
