Results 1 to 9 of 9
    Oct 2012
    Marrero, LA
    Best Prop for Mercury 250XS?
    Currently running a 25P Fury on a 2013 Mercury 250XS. Boat is a 2006 21' Champion Elite 206. Chine walking pretty good at 65mph, while turning 5200rpm's, WOT is yet unknown. Wanting the speed with a little more bite.
    BTW, the 2006 225 Evinrude E-tec take-off is for sale!
    Jul 2005
    Locust Grove, OK
    Quote Originally Posted by bdbeau08 View Post
    Welcome to S&F!!!!
    Sounds like your setup is off a little? May need to raise the engine a little to help
    eliminate the chine walking. It normally starts around 65 mph when the motor is too low.
    You need to get past that & get some good numbers of rpm & speed before we can help
    with a prop recommendation.
    I know a lot of guys with your combination run the Fury & seem happy with it... especially after I put my "mod job" to them!!!
    So, work on the setup some more & we'll be able to help you.
    Thanks,
    Tim Bostic
    Hoss Marine Propellers
    www.hossprops.com
    918-479-5167 (shop)
    Pugh Hydro w/260 Merc - 12" mid
    1987 XB2002 Allison w/2.4 EFI Merc - 15" mid
    1985 XR2002 Allison w/2.4 EFI Merc - 12" mid (Restoration Project)
    "New" - 1987 XTB21 Allison (Refurbished at the Factory!!!!) w/'99-225 ProMax Merc
    Top Speed Blog - http://www.screamandfly.com/blog.php...OSS-quot-Style
    Sep 2011
    Quitman, TEXAS
    the fury is the most common prop on that rig.
    however a modified tempest depending on weight of a 25 or 26 is much better.
    reason is.. you can run a tempest higher and it helps eliminate the chine walking.
    98 XR2001 Drag w/pro stock mota
    Jul 2008
    Binghamton, NY/ Raquette Lake, NY
    I use a 27p Trophy Plus.
    '72 Glastron GT-150 Johnson Stinger 65
    '83 Hydrostream Varmint 2.4 225 Mercury
    '05 Hydrostream Voyager 250xs optimax
    Oct 2012
    Marrero, LA
    Quote Originally Posted by Hoss Marine Propellers View Post
    Welcome to S&F!!!!
    Prop Shaft is ~ 4" below pad. Also, Fury prop has all three solid (PVS) plugs installed, would this have any impact on my holeshot being terrible as well? I don't believe these plugs have any impact on top-end speed, although I could be wrong.
    Jul 2008
    Pull the plugs. That will definitely help with holeshot.
    If you find that it ventillates too much getting out of the hole then put one or two back in.
    Oct 2012
    Marrero, LA
    Quote Originally Posted by gregpro50 View Post
    Will definitely give this a shot. anyone with an opinion on the motor height?
    Jul 2005
    Locust Grove, OK
    Yeah, 4" below the pad is on the low side. When you trim out, the cavitation plate starts dragging in the water
    causing the dreaded "chinewalking".... the solution is to raise the engine. Do not raise it too high & loose water pressure to the engine. Also need to check for any looseness in the steering or mounting systems. If you can shake the motor back & forth, then when you get up to speed and have to start "driving" the boat, you'll always be behind trying to catch up with the walking.
    Hope this helps a little?
    Good info about the vent plugs!!!
    Last edited by Hoss Marine Propellers; 10-11-2012 at 01:12 PM. Reason: added content
    Thanks,
    Tim Bostic
    www.hossprops.com
    918-479-5167 (shop)
    Sep 2011
    Quitman, TEXAS
    jmo
    Fury's don't come with vent plugs in the barrell. never had to put em in when that prop is on a mercury.
    i'd set the prop height at 3.5" below pad with a fury.
    3.25 below with a tempest.
    test from there.
    the 206 champ's just don't run really good with a motor really high. that's why so many guys love the fury on the 206 and 210's killer holeshots.
