Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 46
    Jul 2017
    Dothan, AL
    2.5 150 too cold at idle?
    I’m in the process of rigging a 2.5 150 and putting it on my varmint project. When running the engine, I’ve noticed that it never really gets to operating temp, 95°F - 100°F according to my infrared temp gauge, after a 15-20 minute run time. Tell tale stream is pretty much instant on start up, and does get lukewarm to the touch. Water pressure gauge is about 8 PSI and steady. Brand new impeller, and thermostats. The thermostats are aftermarket ones with the tiny bypass holes in them. Is it possible that the poppet is stuck open? I’d like to see a little more heat in this motor, not really in the mood to cold seize it. Any ideas?
    Feb 2014
    Missouri
    8 sounds high for idle, open popets should have it very low under 3.
    But 8-9 is normally open pressure......
    i would look for whats shooting pressure so high.
    Jul 2017
    Dothan, AL
    I guess ill run a compression check to rule out a head gasket. Other than that, I’m at a loss for right now.
    Apr 2018
    Missouri
    Just went through a similar situation with a 92 150XR6.
    Water pressure 6psi at idle and would not increase with engine rpm. Replaced T stats with Merc brand t stats. Replaced poppet valve diaphragm and spring. Now have 2psi at idle and water pressure increases with engine rpm. At idle you should have about 2 to 3 psi, somewhere north of 1500 rpm is when the poppet valve begin to come into play and you should see somwhere around 9psi. At WOT water pressure should be a min of 12. Sorry I cant be more specific but I dont have my manual handy. Hope this helps
    Jul 2017
    Dothan, AL
    Quote Originally Posted by Iron Horse View Post
    very good info, thanks. I’ll pull the poppet apart and see if anything stands out. I searched and search last night for a similar scenario. I found way more overheat posts than I did too cold posts.
    Apr 2018
    Missouri
    Quote Originally Posted by Blacknsilvr View Post
    Here is an additional tip about your condition. Higher than nromal water pressure at idle can cause a rough idle condition also. If your engine is carbed it most likely will have a Thermal Air Valve on the odd cylinder bank. If CHT. doesn’t reach 100 deg. The valve wont open and port air to the carbs to lean the mixture out. Just an fyi for you.
    Jul 2017
    Dothan, AL
    I know what valve valve you are talking about, and it was somehow bypassed when I got the motor. Just the valve with no hoses hooked up to it basically.
    Another problem..... yay.
    88/12 reaction 19 (sold)
    77 hydrostream varmint 2.5
    02 Caravelle interceptor 212 5.7 GI-B
    I would verify t-stats opening correctly in a pan of hot water. 143 deg is correct for most v-6 mercs.
    Jul 2017
    Dothan, AL
    The aftermarket thermostats have weep holes drilled in them. I’m thinking that may be factoring in to the equation. I have a set of merc thermos on the way.
  10. Likes XstreamVking liked this post
  11. #10
    Apr 2018
    Missouri
    Only one of those ports on the TAV has a hose connected to it. The other port is open to the atmosphere. If that valve is not connected to your carbs you probably need to re-Set the idle mixture screws after replumbimg the valve to the carbs. Do you have a maintenance manual for that engine? I would highly recommend getting one if you do not.
  12. #11
    Apr 2018
    Missouri
    Good point!! On the after market T stats.
  13. #12
    Jul 2017
    Dothan, AL
    I’ve got an older one I can reference off of. I just want to tackle the heating issue right now, the TAV valve I will mess with later.
  14. #13
    Jul 2017
    Dothan, AL
    I also keep keep the search button on fire on here anyways
  15. #14
    Sep 2017
    Ashland city tn
    I agree with poppet and double check stats. If either dont fix. its in adapter
  16. #15
    Jul 2017
    Dothan, AL
    Quote Originally Posted by Merc 2.5 View Post
    Fingers crossed lol.
  1. Mercury Tech: -85 200 2.4 rough idle, stumble, extreme fuel consumption, cold idle
    By Roos in forum Technical Discussion
    Last Post: 08-11-2014, 06:21 AM
  2. Replies: 11
    Last Post: 08-31-2010, 10:27 AM
  3. 2.5/260 - Water Temp: How Cold Is To Cold?
    By Pachanga_rick in forum Technical Discussion
    Last Post: 07-12-2008, 06:02 PM
  4. idle problems when cold
    By craddock in forum Technical Discussion
    Last Post: 07-13-2007, 02:26 PM
  5. Cold idle smoking
    By gtsmpuc in forum Technical Discussion
    Last Post: 09-23-2001, 09:10 PM
