Results 1 to 15 of 36
Thread: Digital ECU
06-14-2020, 10:26 AM #1
Digital ECU
I want the most recent version Mercury digital ECU for a 300 drag. Who has them available? Not going to use Brucato.
The evidence of poor quality lingers much longer than the success of meeting a budget.
06-15-2020, 09:39 AM #2
Call Mercury Racing if you want parts they produce , or had made for them once apon a time. If / when , sticker shock or they just blow you off , try …… >
Monty Racing is a dealer for the new FuelTech ECU dashes . Independent fuel and spark control built into the dash pod.
https://www.fueltech.net/
06-15-2020, 04:54 PM #38000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Do you want the programmable mercury 849 or the new merc digital a13 those are not programmable another option is Brendan power has a new ecu that is coming out shortly and it is a really good one
06-16-2020, 10:05 AM #4
I have a 849 that has taken a dump, way too rich, wanted to try the A13. I have no idea why the 849 went south. Going to replace chip with one from Marles but I’m not sure it will clear up my issues. It’s a cheap enough option to try.
06-16-2020, 10:16 AM #5
849's don't take a chip. You probably have a 11350.
06-16-2020, 11:21 AM #65000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
..If you have a DDT,,plug it in and the temp readings should be your local area temps,,,if your temps say 225 your temp sender in ecu is bad,,,it will run rich.Check the M.A.P
sensor reading....base line from merc is 160 on 4 button and 14.6 on otc or merc with cartridge..Your ecu can be repaired if those sensors are bad.
MUDSHARK liked this post
06-16-2020, 11:26 AM #7
Who can repair the ECU if the sensors are bad?
06-16-2020, 12:37 PM #8
06-16-2020, 04:57 PM #98000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
06-16-2020, 08:04 PM #10
My bad, I have 2 of them and didnt know that!
06-16-2020, 08:26 PM #115000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
06-17-2020, 05:20 AM #12
The 11350's have removable Chips that can be replaced as you and I both know. The 849849 A6 has a PROM (Programmable Read Only Memory) chip (its PROM code is 7119) its manufactured as blank memory then programmed but its potted and cant be removed but can be reprogrammed. The 849849 A 13 doesnt have a Potted PROM Chip. Its a ROM (Read Only memory) and is Programmed during the Manufacturing process and cant be reprogrammed.
06-17-2020, 04:47 PM #138000 RPM
- Feb 2007
- lily lake WI
- 3,206
- 57
- 1561
- 342
Capt.Insane-o liked this post
06-18-2020, 11:43 PM #14
Did 2 fattened a6 chips last week
Michael J Giesler liked this post
06-22-2020, 08:44 PM #155000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
WTB- Digital Delay-Digital Trim Timer
By TripleA in forum Parts WantedReplies: 0Last Post: 03-07-2016, 11:25 AM -
Digital SLR or not?
By Mike2002 in forum Media Creation - Photo and Video DiscussionReplies: 6Last Post: 07-21-2005, 06:09 PM
