Results 1 to 7 of 7
    May 2006
    Sugar Grove IL./Eagle River WI.
    Allison trans queston
    My son recently bought an older Chevy p/u with the fuel efficient 8.1 and Allison trans. Has about 150k miles. He doesn't know the service history on the trans but wondered if it should be serviced. Our experience with conventional trans has been if it hasn't been serviced ever or in a long time and then do a fluid and filter change, it's a death sentence for the trans. Is the same true with the allisons? Should we service it? Or.... if it works- don't mess with it? Thanks
    ft pierce fl
    i agree with the death sentence of new fluid in a varnished up trans. but disagree with your fuel efficient 8.1 statement.
    May 2006
    Quote Originally Posted by davemvegas View Post
    What do you mean? He gets about 8-10 mpg
  4. Likes davemvegas liked this post
    Minnesota
    Why is it a death sentence to put new fluid in an old trans.
    Quartermaster
    XB2002 W/S3000
    May 2006
    Quote Originally Posted by Scott in MN View Post
    They say that the new fluid will loosen up any deposits or crud and then jazzing it up. I by no means am an expert, therefore the question.
    May 2014
    Livingston, Louisiana
    That's correct, trans fluid has a lot of detergents that'll loosen up wear material that is in its happy place, and it'll get into the valve body and clutch pistons and cause them to stick and not move freely resulting in trans damage. Check condition of trans fluid, is it discolored or a darker color and how does it smell. If it's still reddish and doesn't have smell other than trans fluid you'll be ok to change. If it's discolored or has a smell don't mess with it.
  8. Likes sonicss33 liked this post
    Cudjoe Key FL
    Also you could just pull the external spin on filter and empty it to see what it looks like. Remember there are 2 filters on it. Internal and external.
  1. Queston on lower's
    By akuczera in forum Technical Discussion
    Last Post: 08-26-2016, 08:15 AM
  2. Oil Queston?? Need Help!!
    By Ktrain in forum Technical Discussion
    Last Post: 07-12-2006, 09:51 PM
  3. Queston>>>>>>
    By reefhead99 in forum The Scream And Fly Lounge
    Last Post: 09-23-2005, 01:33 PM
  4. Fuel rigging queston
    By Techno in forum Technical Discussion
    Last Post: 04-06-2003, 09:13 AM
  5. queston for racer
    By speedracer in forum Technical Discussion
    Last Post: 03-31-2002, 02:14 PM
