Page 32 of 50 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 466 to 480 of 740
  1. #466
    8 Post(s)
    Quote Originally Posted by Captain75 View Post
    The barrier you are supposed to add between the combustion chambers IOT prevent cooling water to pass. Supposed to be done when running open deck heads on a closed block.
    got it.
  2. #467
    Aug 2011
    Lake Mälaren, Sweden
    Kind of low tempo over here during the holidays, but some smaller details in place, like drilling and tappning the closed deck block to accept the open deck check valve:
    Btw does anyone know the difference between these to types of main bearings?
    Newer design?, better?
  3. #468
    Aug 2011
    No ideas on the bearing differences?
  4. #469
    MIAMI FLORIDA
    I don't know for sure but probably just a different supplier, new ones look like the one with circles on the sides not the raised areas... A more solid cage edge may retain oil better..Dave
  5. #470
    Aug 2011
    Quote Originally Posted by H2OPERF View Post
    Thanks for your reply and thoughts!
  6. #471
    Any difference in roller size. I measured between Merc and ProMarine on rod roller and Merc was smaller. Shorter - .0165
  7. #472
    Aug 2011
    Thanks, FMP!
    I’m on vacation on the Canary Islands, but I will check this when I get home to Sweden and post the result!
  8. #473
    Aug 2011
    Here are the resultats. Sorry but my mic only shows mm.
  9. #474
    Aug 2011
    The hunt for details prior reassembly continues...
    About the connecting rods; is it a good idea to polish the rod journals before reassembly? Like a slight hone creating som small scratches for the oil to stick to?
    A slight rub by hand with 400 wet paper?
    Greatful for your opinions and advice!
    //Anders
  10. #475
    May 2014
    Livingston, Louisiana
    Yes, I always do anyway. I use a little 400 grit ball hone. By hand is fine too, just try to make cross hatches when doing it. Great thread btw.
  11. #476
    Will you use the + 0.59mm?
  12. #477
    Aug 2011
    Haven’t decided yet. The wider cage with slightly smaller rollers seems more solid in your hand, so I might use them instead.
  13. #478
    I decided on more roller surface instead.
  14. #479
    Aug 2011
    Did you have the same parts/choice?
  15. #480
    No , different applications, Merc part vs Pro Marine . Metal cages ,old x flow but the difference surprised me , made it note worthy. A bit extra running surface may help.
